allis chalmers garden tractor
fabricator2009 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote fabricator2009 Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers garden tractor
    Posted: 05 Mar 2016 at 8:01am
Morning. I'm new to Allis Chalmers. Looking for my first garden tractor. I really like the 620, 720 styles. Anything I need to look for, stay away from? If anyone has something for sale . let me know. Thanks.
tadams(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tadams(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2016 at 1:34pm
Go to the clasified section there was one for sale
ac fleet View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac fleet Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2016 at 9:08pm
Garden tractor OR lawn tractor????----Garden tractor would be the 900 series, I use a re-powered 917-H to garden with but lawn unit is a 516 -H and wont do gardens . thanks; ac fleet
macvette View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote macvette Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2016 at 10:41pm
620/720 will do lawns or gardens.  Mower deck cuts 60" and does an extremely even job. I just bought a very old and worn 48" rototiller for rear last fall, and it does a fantastic job with the garden.  Attachments are quite expensive, but very heavily built.
This is a very large frame tractor, and may be too large for some small areas.  Doesn't take long to cut a lawn when you mow 60" at a time.
Generating systems are very touchy on these.  (mine included-doesn't work)  A lot of owners have put a small alternator on to cure this problem.
The toggle/safety switches are getting old, and stay open and can cause a failure to start sometimes.  Relays are sometimes added into the ignition system to work around these. I had done this, until that quit working also.  I then added a separate wire from ignition switch to starter with fuse inline to eliminate this problem.  (probably not a good fix if you have young children around who can use the key in the ignition to start tractor)  I don't have any little ones around.
My Onan seems to generate a lot of power, but repair parts are extremely expensive.  You may see some owners re-engine with Honda, Kohler, B&S if their Onan is really gone.  Cummins now owns Onan.  I believe Small Engine Warehouse sells kits for this.
These series tractors have a 3 speed manual transmission, with a Sunstrand hydrostatic transmission, giving a tremendous variance of speed and power.  You can crawl along, yet have tremendous power at your hand.
Guess you can tell I really like mine, even tho I don't have a working charging system.
Edited by macvette - 06 Mar 2016 at 10:43pm
coggonobrien View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote coggonobrien Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2016 at 7:02am
I will have a 616 for sale in the next couple months as soon as I get my 2nd one running
NATHAN CAIRNS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NATHAN CAIRNS Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2016 at 12:11pm
b212's were made in the 70's and are great    I have one, but I also have an old 6 something hydro with a mower deck that I plan on fixing one day
B212, WD45, B, 912 Hydro
it is a 616
This page was generated in 0.219 seconds.
