allis chalmers electric forklift help
lsczzzz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote lsczzzz Quote  Post ReplyReply Direct Link To This Post Topic: allis chalmers electric forklift help
    Posted: 08 May 2014 at 10:19am
I have old allis chalmers electric forklift.
batteries are charging but, i can't seem to release the brakes.
No side brakes, i believe its auto brake when its off.
anyone know where i can release parking brake without power?
i need to move this under roof before i do anything.
by the way, i need help finding what fuel tank that is.
Edited by lsczzzz - 08 May 2014 at 10:21am
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2014 at 11:12am
Hydraulic Tank?
Mrgoodwrench View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2014 at 11:19am
Some had a cyl that run a park brake.   I believe it runs with the steering pump. Does the truck try to run?
den/southern illinoi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote den/southern illinoi Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2014 at 6:29pm
My electric forklifts have an automatic brake when you get off the seat.
The seat comes up like yours and the rod engages the brake.
The tank almost has to be hydraulic since it has a breather on it.  That's an opinion as mine are not like that.   Den
Edited by den/southern illinoi - 08 May 2014 at 6:30pm
Own 4 wheel 20, 5020 and associated equipment and 1 electric forklift. Also a 720 garden tractor, 720 Diesel. 620 and soon a 616 garden tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mrgoodwrench Quote  Post ReplyReply Direct Link To This Post Posted: 08 May 2014 at 9:13pm
That is definatly the hyd tank.    If there is an additional auto. brake then it will be attached directly to the drive motor.
