Allis Chalmers D17
jeffgarc12 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffgarc12 Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers D17
    Posted: 10 Aug 2020 at 3:23pm
I have an Allis Chalmers D17 that I had parked outside for the night and it started right up when I moved it out of our shop but the next morning, nothing. I was also wondering if the D17's were positive grounds
Boss Man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Boss Man Quote  Post ReplyReply Direct Link To This Post Posted: 10 Aug 2020 at 6:01pm
If it hasn't been converted to an alternator it should be positive ground.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 8:05am
Positive from factory....check which battery post is grounded. Could be like my cousin's where he replaced battery and hooked up neg ground. Still started and ran....ignorance is bliss.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffgarc12 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 4:54pm
But what could cause not to start, it is not doing anything at all after I turn on the fuel and turn the key no clicks no nothing.
CrestonM View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CrestonM Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 5:29pm
I would check to see if you have power at the battery, distributor, and starter. A test light is useful for that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote jeffgarc12 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 6:13pm
Could it be shorting out along those spots
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Aug 2020 at 9:16pm
Clean and tighten all connections. Sounds like you lost conductivity or else the battery died. Don't know if regulator could stick points and run system down when off? Doubt you are shorting anything. You would be cooking wiring somewhere.
Edited by SteveM C/IL - 11 Aug 2020 at 9:17pm
frnkeore View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote frnkeore Quote  Post ReplyReply Direct Link To This Post Posted: 12 Aug 2020 at 12:55am
In this case, the first thing I would do, is pull the battery or pull the cables off it and charge the battery. Then take the charger off and test the voltage. That will tell you if the battery is good.
The battery has to hold a charge, before you can check anything. A quick check for battery drain, if the battery is good, is to take one cable off and then touch it the battery terminal. If everything is off (including ign switch), and there is any spark, there is a drain somewhere.
But, first check the battery, they can die, overnight. It has happened to me.
Frank
1959 D17 Series I #24001+, '59 D14
'55 & '59 Ford 850 & 861
Ferguson TO 35 Deluxe, Oliver 70 and 5 more.
