Allis Chalmers D17 Propane Side Shields
CORY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORY Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers D17 Propane Side Shields
    Posted: 07 Dec 2023 at 11:37am
Are the bottom halves the same as a gas tractor?  Or does anyone have a picture of a set off the tractor?  Just trying to figure out what is missing on my recently acquired propane.
Thanks
Cory
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 6:07pm
Here is a Link to pictures of a D-17 Propane which has side panels below the Propane Cylinder.
G
https://www.mecum.com/lots/322759/1958-allis-chalmers-d17-lp/
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2023 at 9:04pm
You can make them out of gas tractor side panels.
However
There is an additional panel/cover that goes between tank and instrument panel.
It most often is missing.
IBWD MIke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote IBWD MIke Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 8:58am
Cory, is you're tractor an original propane or a conversion? They did quite a few conversions on 45's, I assume they did 17's too. At any rate, the sheet metal would be different.
CORY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CORY Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2023 at 10:26am
Factory LP Series II.  The shield underneath the tank going around to both sides is there.  It appears as in the picture that was posted as well as on mine that the side panels from a Gas would bolt right in there.(I have not taken the time to try as the tractor is currently at work and not at home)  What is odd is there is part of the one underneath the tank on left side as sitting in the seat but it appears to be a factory? cut right where the steering shaft comes in at an angle.  I would gladly text pictures to someone that knows how to post them on the site.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 09 Dec 2023 at 7:54am
Parts book just lists same panels for both gas and lp. Just has additional panel extension under tank.
