Allis Chalmers B project |
Page <12 |
| Author | ||||
DiyDave
Joined: 11 Sep 2009 Location: Gambrills, MD Points: 54975 |
Posted: 18 Jan 2026 at 8:07pm |
It looks like they are there, the 2 items to the right of the gold colored shaft...
| Sponsored Links | ||||
PeterVD
Posted: 19 Jan 2026 at 6:31am |
No letters/numbers on the carb, can anyone tell me if this is a Zenith or a Marvel Schebler carb?
Restoring a Allis Chalmers B
Gary Burnett
Joined: 11 Sep 2009 Location: Virginia Points: 3164 |
Posted: 19 Jan 2026 at 7:45am |
Zenith
wjohn
Posted: 19 Jan 2026 at 8:20am |
That is a Zenith, but I have never seen that style on a B. If you look at where it mounts to the manifold, it looks smaller than it should be. I wonder if it came off of something else and is not the original carburetor... Unless that is what Bs built in the UK used?
Edited by wjohn - 19 Jan 2026 at 8:23am |
PeterVD
Posted: 19 Jan 2026 at 3:02pm |
According tot Google the UK build B's have a Zenith 24T2 carb, and mine looks like it think https://www.da7c.co.uk/technical_torque_articles/zenith_24t2_carburettor.html Edited by PeterVD - 19 Jan 2026 at 4:12pm |
Joined: 11 Sep 2009 Location: illinois Points: 89968 |
Posted: 19 Jan 2026 at 4:24pm |
that model is popular in the USA, but was not used on the Alllis..... Several sites list the carb..
Trinity45
Joined: 17 Mar 2014 Location: Kentucky Points: 2099 |
Posted: 19 Jan 2026 at 5:29pm |
Best of luck, I have a working B with mounted cultivators we use in sweet corn.
PeterVD
Posted: 25 Jan 2026 at 5:28pm |
Is there a possibility to add a foot accelerator on the B ?
Posted: 25 Jan 2026 at 7:47pm |
the INDUSTRIAL MODEL , IB , had a foot accelerator.... couple extra parts and a spring loaded over ride foot feed on the hand throttle......
there is a guy on this site that makes foot feeds for "D" series tractors... might be something to look at... I think its Tracy ?? Edited by steve(ill) - 25 Jan 2026 at 7:49pm |
Posted: 25 Jan 2026 at 7:51pm |
changing the hand throttle to a foot throttle would not be too hard... having BOTH is a litte more complicated becase the hand throttle is at a FIXED position and you want the FOOT FEED to over ride that... IE, the spring.
PeterVD
Posted: 25 Jan 2026 at 9:34pm |
Different sites give different instructions for setting the valve lash, one says 0.25 mm cold, another says 0.25 mm hot... whitch one is right?
Thanks(1)
Posted: 25 Jan 2026 at 9:40pm |
everyone sets them cold.... normally add a couple thousandths to the HOT value... .25mm is .010 inch... normally set them at .012 inch or .30 mm
PeterVD
Posted: 04 Feb 2026 at 6:30pm |
I think the governor spring became a little old/weak.
I have read that is possible tot replace it by the spring for a CA, to gain a little bit of RPM/ speed. Is this correct? |
Les Kerf
Posted: 04 Feb 2026 at 7:22pm |
Yes. |
PeterVD
Posted: 22 hours 33 minutes ago at 10:38pm |
Does anybody know how much NM a CA spring pulls? Original ones not available
Edited by PeterVD - 20 hours 48 minutes ago at 12:23am |
Page <12 |
