Allis Chalmers B project
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2026 at 8:07pm
YEP... sounds like your doing GREAT !!
Thanks Steve Wink
I only have one small problem with it now, the choke has to stay a little bit closed to keep it running, when I open the choke completely the motor drops dead
I hope a good clean of the carburator will help
Or the felt air seals for the choke shaft...Wink
Do you have a parts number for the felt air seals please?
Is it any of these:
It looks like they are there, the 2 items to the right of the gold colored shaft...Clap
PeterVD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 6:31am
No letters/numbers on the carb, can anyone tell me if this is a Zenith or a Marvel Schebler carb?
Restoring a Allis Chalmers B
Gary Burnett View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Burnett Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 7:45am
Zenith
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 8:20am
That is a Zenith, but I have never seen that style on a B. If you look at where it mounts to the manifold, it looks smaller than it should be. I wonder if it came off of something else and is not the original carburetor... Unless that is what Bs built in the UK used?
Edited by wjohn - 19 Jan 2026 at 8:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 3:02pm
According tot Google the UK build B's have a Zenith 24T2 carb, and mine looks like it think
https://www.da7c.co.uk/technical_torque_articles/zenith_24t2_carburettor.html
Edited by PeterVD - 19 Jan 2026 at 4:12pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 4:24pm
that model is popular in the USA, but was not used on the Alllis..... Several sites list the carb..
Trinity45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Trinity45 Quote  Post ReplyReply Direct Link To This Post Posted: 19 Jan 2026 at 5:29pm
I'm Peter, 54 years old and located in Belgium.
I started a rebuild project together with my 18 year old son, an Allis Chalmers B
It runs and drives, but not as it should, so we got a little bit of work in the future
It's already converted to 12 Volt
When I find out how I will post some pictures on the forum
I don't know if this works:
Best of luck, I have a working B with mounted cultivators we use in sweet corn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 5:28pm
Is there a possibility to add a foot accelerator on the B ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 7:47pm
the INDUSTRIAL MODEL , IB , had a foot accelerator.... couple extra parts and a spring loaded over ride foot feed on the hand throttle......
there is a guy on this site that makes foot feeds for "D" series tractors... might be something to look at... I think its Tracy ??
Edited by steve(ill) - 25 Jan 2026 at 7:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 7:51pm
changing the hand throttle to a foot throttle would not be too hard... having BOTH is a litte more complicated becase the hand throttle is at a FIXED position and you want the FOOT FEED to over ride that... IE, the spring.
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 9:34pm
Different sites give different instructions for setting the valve lash, one says 0.25 mm cold, another says 0.25 mm hot... whitch one is right?
Post Options Post Options   Thanks (1) Thanks(1)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Jan 2026 at 9:40pm
everyone sets them cold.... normally add a couple thousandths to the HOT value...   .25mm is .010 inch... normally set them at .012 inch or  .30 mm
Post Options Post Options   Thanks (0) Thanks(0)   Quote PeterVD Quote  Post ReplyReply Direct Link To This Post Posted: 5 hours 6 minutes ago at 6:30pm
I think the governor spring became a little old/weak.
I have read that is possible tot replace it by the spring for a CA, to gain a little bit of RPM/ speed.
Is this correct?
Les Kerf View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Les Kerf Quote  Post ReplyReply Direct Link To This Post Posted: 4 hours 14 minutes ago at 7:22pm
Is this correct?
Yes.
