Allis Chalmers B Hydraulic Questions
 Post Reply Post Reply Page  <1234>
yochujr View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 11:09pm
Originally posted by pumpkin man pumpkin man wrote:
 in your last pict. it shows a return hose hook to the filler hole  what type hdly. cly is on that tractor could be your prob. show more pict. of the pump & cly. hook up looks like a to way cly. on a one way stym.
Here are the pics.  Let me know if they show what you need.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 11:11pm
Steve M C/IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 11:27pm
It is a 2-way cylinder but is hooked up correct as a 1-way with the other line just vented.Not been around a B but the pumps are similar in principle to a WD45.There has to be a hold valve somewhere and it sounds like it isn't releasing.On a 45 when the shaft rotates it pushes the ball off the seat to release return oil.Does the thumbscrew bottomed out on the spring have anything to do with that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 11:33pm
If we're talking about the same screw, the manual I picked up says that controls the rate of flow.  I take that as how fast it allows the 4-point to drop.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2010 at 11:34pm
Correction, I meant to say 3-point.  It's been a long day....
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 12:06am
I hear ya. Go to  www.agcopartsbooks.com and use the guest user-view books.In the first box type "b" in the second select agco-allis them submit.A bunch of stuff will come up and click on The B/IB/power unit line.When that page comes up you can scroll down to the hydraulics section and look at those.I looked at the fist one and it showed the pump and pieces.You can clik pic and enlarge  till you get it big enough to see.You have to do some "draggin" to keep it on the page.I usually just click the print button instead and enlarge that but you still can't read the no's on that one.Looks to me like the smaller hex plug they are calling the relief and I can't tell what I'm seeing in the picture but on a 45 that shaft has a flat spot that when rotated,pushes the relief open and lets the cyl colapse.Might try loosening/removing that plug to see if something is stuck.I wouldn't have weight hanging on system to try that.Block it up or something.any way,hope this helps.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 1:24am
This looks like it will be a tremendous help.  I was able to view the parts and locate a dealer within an hour so I should be able to call them Monday to see what they have in stock or can get for me.  Thanks!
Bee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bee Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 2:23am
Sandy Lake, a forum vendor is outstanding if your local dealer cannot come through.
Bob, North Carolina
1949 B
pumpkin man View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 11:40am
try removing that return hose from the filler hole could air locked the cly needs to suck air. you dont need return line you need a vent. thy have vent plugs for useing 2 way clys on 1 way sytms or make your own by cross drilling a pipe plug and putting a cotter key in the hole that keeps the dirt out
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 11:57am
for got to ask what kind of oil is in trans syst. book calls for motor oil [ 20 w -15=40 -10 30 - hy-trans] not 80-90 gear lube its to heavy like tar when cold also back thumb screw out llets valve open more.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 12:24pm
I have no idea what's in there right now but I'm sure it needs changed before I do too much.  I cleared out the drain holes (I've heard them called mouse doors) last night and a bunch of water drained out.  The drain holes appeared to have been plugged by a bunch of heavy grease and hair/grass which I assume got in there from a rodent.
As for the return line, you're saying to take the line off the cylinder that's closest to the ram?  Right now, it looks like this goes into the trans just behind where my left foot sits.  If I eliminate that line do I plug the hole it goes to in the trans?
One other thing, I got the I&T manual but it doesn't seem to show any sections on draining all the fluids and filling it, only capacities.  Do the entire hydraulics and trans all run off the same fluid?  I'm sure I'm showing my ignorance but I think I'm starting to pick it up a little.  Thanks again for the helpful posts.  It's nice to know this is one of the few good forums where people are actually willing to help!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 2:36pm
That would be a good idea to try first.When lift is raised and won't go down,just loosen the connection on the line and see if it bleeds off and lets arms crawl down.Then you would know there is no problem with the line or cylinder.As stated,they make "vents" for 2-way cylinders which would be more desirable than the extra hose.Any place that sells cylinders should have them and then just plug the other end/hole that now goes in by your left foot.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 3:54pm
Interesting, so the vent with only allow air out and no fluid?  I will definitely try to loosen that hose.  There shouldn't be any real pressure on it, right?  Also, when I loosen it slightly and if that's the problem they should bleed down but also still raise if I'm understanding correctly?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 4:40pm
Yeah,I'm just saying to crack and loosen the hose that feeds the cyl to see if by letting the oil escape there it will let the cylinder colapse.If the oil bleeds out but the cyl won't compress you got something wrong with the hose or cylinder.If that's the case then remove the hose first to see it blows free then try to compress the cyl.Cyl should be able to compress with no hose by just pushing down on lift arm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 4:46pm
I do know that something is bleeding off as it is because as long as the pto is not engaged, the hydraulics will bleed down with or without a load on it.  After I shut the tractor of after the 3-point is raised, I can push on the drawbar and hear a leak somewhere and I suspect it's in the cylinder.  If that's the case, I can live with that for now as long it will will hold up but I have no way of lowering with the pto engaged.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve M C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 5:07pm
It sounds like it's pumping all the time it's running and won't quit even when put in hold or lower position.Actually they do pump all the time but it should go into bypass mode at hold and lower position.Something must be stuck internally.You should be able to dissaemble,clean and reassemble without buying any new parts.You might find a broken piece but it sounds like something is froze up.I can't believe the "B" experts ain't in here helping out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 5:07pm
I will bet money if you remove the hose that goes back to the tranny fill hole, you will have a mess of oil all over after raising the 3PT. That 2 way cylinder has a leak-by in the piston or the original owner wouldn't have gone to the trouble to run a return line. That side of the cylinder shouldn't have any oil in it unless the piston is leaking. I would also bet the reason the 3 pt goes down after shutting of the PTO is because the oil is leaking past the cylinder piston and following the hose back to the fill hole.
 With the "return" line disconnected and anchored into a bucket, raise the blade up and shut the PTO off. Watch the oil leak out of the hose, into the bucket.
 That still doesn't fix your original problem of letting the 3 Pt go back down. I would leave the return hose in place if the cylinder is leaking by and concentrate on the valve operation until you have more time to mess with it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 6:43pm
Great, thank you all.  It sounds like step one is to remove the entire pump and clean and not worry about new parts.  I will be calling some potential dealers in my area just to see if they have parts available in case and at the very least a new gasket when I go to reassembly.
Since all this attention was brought to the cylinder, I went out and looked it over real well and it appears as though this is not at all original.  Towards the top, where is slides onto the pin to mount it to the tractor, it looks like someone welded the eyelet onto the replacement cylinder in order to get it to work on this tractor.  Maybe this is why is seems to raise a little slow with or without a load.  If I'm not going to mess everything up, I would eventually like to find an original cylinder put back on there but it's got me questioning now whether that 3-point was even original to the tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 9:24pm
were the return hose is hooked to the trans s the fill hole takes a 1 inch pipe plug  you do not need a return line if that cly. has oil in that side [where the return line hooks on]then the cly. is leeking [its junk]cost more to fixthan its worth. ther are 3 dra in plugs on the bottom of tras-rear end-& P T O houseings should have a 3/8 square hole in them take them out one at a time drain each unit refill with fuel oil [with the scraper off the tractor] & P T O off drive it around the yard for a wile then take the pump hose off the cly. put it in a pail  put P T O in gear and work the pump this should flush the pump drain the fuel oil out of the houseings  this will flush the crap out  then refill with oil[motor-oil] [not 80-90 gear lube]  put a ad in the forum want ads for B or C hdl cly.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2010 at 9:58pm
Thanks.  I will also take a few more pics tomorrow of the current cylinder and how it's attached so it will better show my doubts about it being original or for this particular tractor.  I also appears that some brackets were welded onto the horizontal rod that runs along the back of the seat (the part of the 3-point that rotates) and maybe you guys can confirm if it was added.  I apoligize if this is dragging out.  I'm just trying to get every little piece of info I can before I dig in to make sure I'm doing everything right.  I would prefer if at all possible to bring it back to it's original condition when I do all of this and get rid of whatever may have been rigged up from the past.
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 12:18am
yochujr,  That cylinder is at least 50% bigger then the original one and It sounds like oil is leaking past the cylinder, as has been suggested.  The older AC's ran higher hydraulic pressure then other tractors of the time, that is why they could get by with such small cylinders.  I suspect something is stuck in the pump/valve and all the constant pressure on the inside of the cylinder caused it to blow out the o ring/seal in it.  There are a lot of AC's that used the same system so a cylinder should not be hard to find at a reasonable price.  Good luck.
Allis Express participant
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 9:00am
your hitch is a home bilt [looks well made.good for that scraper or a rear mount mower] you will need a reg. B draw bar for pulling hualing heavy loads  if you put a 3 pt. draw bar on those arm s the weight will to far back makeing the front end too lite
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 9:31am
Here are some pics ov how the cylinder and the 3-point are set up.  Is it still possible to directly replace this cylinder with an original one or will it require some kind of fabrication?  There seems to be so many out there, I have not been able to find any pics or info on exactly what my setup is supposed to look like.
uploads/4032/IMG_3117_Large_e-mail_view.jpg
uploads/4032/IMG_3118_Large_e-mail_view.jpg
uploads/4032/IMG_3119_Large_e-mail_view.jpg
uploads/4032/IMG_3120_Large_e-mail_view.jpg
uploads/4032/IMG_3122_Large_e-mail_view.jpg
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 3:58pm
Not for sure but I believe an OEM cylinder will fit. It's shorter but the mounting hole is on the end on the cylinder. And I believe the pin thats welded to the seat frame is the way it came from the factory.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 4:53pm
"If I'm not going to mess everything up, I would eventually like to find an original cylinder put back on there but it's got me questioning now whether that 3-point was even original to the tractor."
The B Allis Chalmers never had a 3point hitch. All were add ons.
were the return hose is hooked to the trans s the fill hole takes a 1 inch pipe plug  you do not need a return line if that cly. has oil in that side [where the return line hooks on]then the cly. is leeking [its junk]cost more to fixthan its worth."
 In 15 years of machine repair work I don't believe I ever scrapped out a hydraulic cylinder. I have made new rods, replaced packing, manufactured and replaced packing glands and even made new jugs for cylinders. If there was a direct replacement available for the application a new cylinder might have been used once or twice. Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 5:20pm
What where the hydraulics originally there for on a B?
Is there an off the shelf replacement cylinder for a farm store that will act as a direct replacement for the original cylinder or something that will work for my application?  I was told on this forum that I shouldn't have too much trouble finding an original for a decent price.  Since it's now looking like everything is going to have to be drained and flushed and they pump needs to be cleaned out, I would like to be able to gather up all the new parts and do everything at once while it's all apart.
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkin man Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 6:03pm
your not listing to what we have told you to do. spend $6 dollors for some fuel oil - drain  the sys. flush it .put new oil in check the cly for leeking then you wiil have some idea  of whats wrong. if it was mine I would get rid of that cly. & find an orgl. you can get one for less than $50 put a want add in the Forums want adds. the pump is working if its lifting up but not going down [right] the return valve is pluged or dirty. thats what the flushing mite take care of if it dosent then tair in to the pump.
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 6:19pm
I'm listening to what everyone is saying.  I'm just finding more and more with this and want to make sure I have everything I need and do everything in the correct order.  I have said before I know nothing about this and maybe this project was a little too ambitious but I'm just trying to learn as much as I can up front so I don't get myself into trouble down the road when I get into.  I apologize if you took anything the wrong way.  All the information you guys have given me so far is priceless.
Is fuel oil the same as what you use for heat?  I'm not familiar with that.
Also, do I just refill with 20w motor oil?
Post Options Post Options   Thanks (0) Thanks(0)   Quote yochujr Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 6:47pm
I knew I got the oil reccomendation from somewhere.  I read back where you was 20w-15 motor oil
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2010 at 7:46pm
buddy, your problem with the original cyilinder is in is about 1 inch bore. If you figure the pump puts out 3000 psi, then you got  2500 # of push on the cyllinder. With all the linkage and  mechanical arms you will see that you can only pickup a 200- 250 pound blade. Been there, done that.  I have one tractor that has TWO of the 1 inch B cylinders and  two others that have bigger cylinders. One has a CA cylinder that is about 2 inch bore, and one has a WD45 cylinder that has about a 2 inch bore. That gives you much more lift in the back. One of the small B cylinders will probably just barely lift a light duty blade. I agree, you have a problem inside the pump that it will not drop. Fix that and see how things work. Your going to get into a little work trying to replace the cylinder since the mount,  diameter, and rod length varies between cylinders and require modification.
This page was generated in 0.238 seconds.
