Allis B ?
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 01 Mar 2010 at 9:47pm
At a glance you can tell all the parts on this tractor are not 1941 vintage by the age of the paint. Somebody has come a long way into restoring this C into this nice condition. Looks like a new steering wheel and front wheels. Cs with short steering arms were used up to C18162. Foot brakes on Cs started at C5756.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 1:19am
This C has a C steering box on the front, but the bottom part of the wide front, square tube and wishbone are CA! A C wide front has the braces that go out to the square tube that come out from the wishbone coming much farther out toward the spindle area. Also the brace is just cut off on the end instead of being machine flattened on the ends like this one, as they were on a CA. I am sure it is a C & CA morphed together, still looks pretty nice though. I would post a picture of my C wf but its not here at the house right now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 8:04am
From looking at parts book drawings of C and CA widefronts the most obvious difference is how the pivot bar braces are welded in.  On a C the short brace is on the top of the long pivot bar wishbone  which have a bend in them.  On a CA the short brace is on the bottom of the long pivot bar wishbone  which is straight. Can't really see this in the photo of the front axle back in page 1. Both short braces appear to be welded to the box tube in the same place near the ends on both the C and the CA
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 02 Mar 2010 at 9:02am
Probly right Rich. I would guess the top casting and short arm was from a narrow front and was not removed and the CA wide axle was bolted to it.
I never tried that switch but it always looked like it could work.  That would just be a four bolt chore and one pivot nut. No tin, drag links or radiator to remove.
Seems the way to go if you like that short arm.
This page was generated in 0.073 seconds.
