Allis b Ross steering box
Hardwater000 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Topic: Allis b Ross steering box
    Posted: 25 Oct 2024 at 6:11am
Can someone please tell me if the pin that rides inside the worm gear is round or oblong? I have looked at various pictures and it appears to be round and somewhat coned down. I need to build mine up and like toget it shaped right the first try.if anyone has any measurements that would be great to...Tia
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 2:19pm
saw this on the internet several years ago.. I made a couple useing these numbers.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 2:31pm
That helps a lot thank you.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 25 Oct 2024 at 10:26pm
Do have part number
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 6:07am
Mike, I don’t think Allis ever sold just the pin, parts book only shows the lever the pin is in, Deere did sell the pin alone, Allis chose not to.
Edited by JoeM(GA) - 26 Oct 2024 at 6:08am
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 7:15am
Yes sorry that’s what I meant. We have some nos shafts
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 11:38am
My pin does not appear to drive out. I used a punch but no outline of the pin on backside of shaft. Numerous post I have studied on says they drive out. And another question I have 20 ball bearings but looks like it could easily hold at least 1 more any info much appreciated
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 12:27pm
Nos shafts is that your personal collection or for sale?
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 1:56pm
If you just touch the back of the arm where the pin is with a flap disc, you’ll see the outline of the pin, it’s in there good!
Parts book calls for 20 balls for B & IB, 24 for C
Edited by JoeM(GA) - 26 Oct 2024 at 1:58pm
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 2:49pm
no way the pin could be MADE on the end of the shaft. It has been pressed in... I have had to center punch and drill one out before that was TOO TIGHT..... also possible that someone instalaled a new pin and welded the back side, then ground it flush so it looks like one piece ?
YES-- 20 balls as shown in the drawing.. you want some clearance for them to roll and carry oil / grease.. Very low speed application.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Posted: 26 Oct 2024 at 3:43pm
May of been welded haven't gave up yet. On the bearings I will recount again but it appears that I had plenty of room for 1 maybe 2 but they do need room for oil and grease like said above
Kiwi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kiwi Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 4:06am
Hi I knocked my pin out turn it 90 degrees and put it back in so it now runs on the unworn face.
Tractors Allis EB,two C,diesel G
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 5:40am
I read on another topic while searching that someone did that, but mine is wore bad enough that it has to be reworked or try to buy a new one probably will rework considering the prices I have seen on new pins.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Oct 2024 at 7:57am
the first couple i did, i welded up the pin , in place, and ground it back to a cone shape with a hand grinder... At that time i didnt know the pins came out and you could buy new... AFter the first couple, i drill out the old and made new pin on the lathe out of a grade 8 bolt.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Hardwater000 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 9:20am
That is a good idea with the bolt. I maybe able to turn it down locking it into a drill press bc I don't have a lathe. Much easier I think than welding what little of the pin is left. I believe maybe it has been welded from backside and ground down I ran a flap disk over it and it's the only thing I can think of why I can't see the outline of the pin.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 9:57am
Do you know part number of shaft
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Oct 2024 at 10:59am
70211001
LEVERSHAFT (TR. B-101 & UP) (B & IB)
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 02 Nov 2024 at 12:20pm
Thanks Joe. I’ll check that number
This page was generated in 0.060 seconds.
