Allis 8030 powershift problem
Jake_bbltz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_bbltz Quote  Post ReplyReply Direct Link To This Post Topic: Allis 8030 powershift problem
    Posted: 16 May 2011 at 10:05pm
I have an AC 8030 that has a 6 speed high and low powershift. It just started acting up and drives fine 1st through 5th, but when trying to shift to 6th it will not engage. All linkage looks okay, is there anything internal that is a common problem for this? Any help would be appreciated thanks!
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 10:07pm
If the return spring on the clutch pedal has broken inside the dash and not allowing the clutch pedal to come all the way up, you can't hit 6th.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_bbltz Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 10:13pm
Thanks! So by manually pulling up on the pedal can I try and shift it to 6th for troubleshooting that?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 16 May 2011 at 10:16pm
Yes   do it in park and sitting still.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jake_bbltz Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 10:21pm
I looked at the tractor today and the clutch is definitely coming all the way up. Any other ideas or are we now into internal trans problems?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 17 May 2011 at 10:36pm
Look over the linakge behind the batteries and make sure the lever on the valve body is pinched tight to the shaft. Also make sure there's no loose or worn out linkage in the console where your PST lever is. Outside of that, assuming you haven't made any adjustments/changes to anything behind the batteries, remove the valve body and see what's broken on the shift mechanism.
Orange Blood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Orange Blood Quote  Post ReplyReply Direct Link To This Post Posted: 18 May 2011 at 7:59am
When you say linkage is ok, are you sure it's adjusted properly, if it is out of adjustment one way, it won't detent into 6th gear, since it hits the stops in the cab first, our 7060 did that once.  Open the batteries, watch the tranny end of the cable, and carefully feel the valve body shift lever, have someone shift it, without the motor running, and make sure there is a possitive detect between 5th and 6th.
Still in use:
