Allis 7040 turbo
Mattman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Topic: Allis 7040 turbo
    Posted: 29 Aug 2024 at 11:45am
Any suggestions on a bolt on Turbo upgrade for a 426 in a 7040?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2024 at 11:50am
I guess the first logical question would be, why ?? If you aren't increasing the fuel delivery, why change the turbo ??    If you have a Rajay brand turbo, it may need replacement, as they weren't nearly as long lived as the Air research brand.  An 8030 turbo would be a nice small change but NOT a bolt on. It is the same as 8050-8070-7080-7580-4W220 and it made for 220 flywheel HP right out of the box.
Edited by DrAllis - 29 Aug 2024 at 1:23pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2024 at 1:24pm
If it had a RayJay, then an Air Research would be an upgrade, in my opinion.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 29 Aug 2024 at 2:04pm
That would be right, Lynn. !!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mattman Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 8:00am
Thanks Guys! I do plan on sending a little more fuel down the pipes.
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 8:04am
An S200 is a great upgrade to those tractors, I've sold a few to guys that I set up their fuel systems on these. Much easier to fit on a 7000 series tractor lol!
JPG AUSTRALIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 8:50am
So Ed,what is the improvement that the s200 does ,earlier boost? More total boost? I have boost gauges on 3 of my 7000s that do field work and I know they dont make a lot and it doesn’t come in till nearly 2200
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 8:58am
Factory turbos are designed to start building boost a 17-1800 RPM (except 7080/7580/8070) and the more RPM you have, the more boost there is. I had a customer 40 years ago that had a 7020 and HATED it !! compared to his trade-in 200 tractor. His dealership had worked on it with zero improvement. He brought it to me and within 30 minutes he now LOVED his 7020. Problem ?? injection pump was timed at 20 degrees BTDC instead of 18 degrees and I placed it at 16 degrees and boost came in much sooner and was a completely different tractor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 11:35am
Hey, Ed.  Are the S-200's you are talking about a direct bolt on to the T0-4B series on the 8030-50-70 ??  or more fab work still needs to be done ??
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 1:44pm
Nothing is a direct bolt on replacement except the T04 replacements I sell. The S200 uses a V-Band exh outlet, so you have to fab up a new exh outlet/stack, but with a huge oval hole in the hood, it's a piece of cake. I also sell flange/clamp and elbow if needed. Sometimes that stuff is hard to find locally. The crossover pipe will need some modification, as this turbo sits a little different. The oil inlet can be made to work with slight tweaking, oil drain requires a little bit of grinding on the oil drain pipe flange and exh manifold if I remember right. The connecting air cleaner will require adapring up to the 3.5" hose connection. The S200 is a modern MAP groove turbo, which when paired with the correct size exh housing will spool up a lot quicker, for excellent response.
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 5:23pm
Anybody know the AC stock engine’s NON-load (high idle rpms)& LOADED (500rpm decrease) turbo boost psi (ball-park #s)per the 7000 & 8000 series tractors?
Thanks
Edited by AC7060IL - 30 Aug 2024 at 10:14pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Aug 2024 at 8:26pm
High idle no-load boost is irrelevant.    8030 at full load 2300 RPM should be 13 to 14 psi boost......8050 at 2300 full load 15 to 16 psi boost......8070 at 2400 RPM should be 18 lbs boost.  All at 60 to 70F degrees air temp.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2024 at 9:27am
So Ed, the twin scroll on the s200 turbo is fine onto the allis single exhaust manifold outlet?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 07 Sep 2024 at 10:12am
It is, fine
Post Options Post Options   Thanks (0) Thanks(0)   Quote JPG AUSTRALIA Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 5:19am
Picked up an s200 today of marketplace, bargain at $300 US. Pretty happy, as its brand new,guy bought the wrong one and wanted it gone.🙂
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 20 Oct 2024 at 3:18pm
totally different S200 than I referred to, I'm referring to the S200SXE super core series. That one is wastegated, which probably isn't a bad thing if got it right lol.
