Allis 400 loader
TGerber View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TGerber Quote  Post ReplyReply Direct Link To This Post Topic: Allis 400 loader
    Posted: 04 Nov 2010 at 11:40am
Hi Guys
I was wondering if an Allis 400 loader will fit on a 175 without a whole bunch of fabrication needed.
Thanks
Terry
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 11:45am
I am thinking it should fit with the D17 brackets.   If the frame rails are the same width.   I am sure there will be drilling involved.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 04 Nov 2010 at 5:00pm
400 is the Series model of the loader.
445 on a WD-45, 414 on a D-14, 415 on a D-15, 417 on a D-17.
and then you have the 500 Series:
517 on a D-17 Series IV, 519 on a D-19, these do not have the pump mounted out front.
What Series and model do you have ?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote TGerber Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 7:18am
The sticker on the loader frame says 400, it is currently mounted on a 5045. I just assumed it was a model 400 loader.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TGerber Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 7:21am
- oh and the pump is not mounted out front. - Hope this helps Thanks for the replys.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 7:24am
yes there was also a straight 400 model loader. with no hydraulic resivior in the frame.
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Nov 2010 at 7:29pm
Yes I believe the 400 was the one you tried to sell to fit on other color tractors. Lots of universal brackets with it. Should fit 175. I think the 400 even fit the 7000 series.
