Allis 175 hydraulic pump input shaft
steve(oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Topic: Allis 175 hydraulic pump input shaft
    Posted: 30 Jul 2023 at 1:42pm
Happy sunday. Can I take this shaft out with out running into problems of stuff dropping behind it. Or how do I go about it? Split the tractor for the clutch and the bushing was hanging out on the smaller input shaft. IMG_6041.jpeg
When your working on something how does it always seem that merphy's law come into affect?
Wide open, Untill you see God. Then Brake
8070nc View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 8070nc Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 1:51pm
I dont know what Doc or Mack would say but I think Id get a new bushing and put some locktite on it and tap it back in there.
1984 80780
1957 D14
DES 300 with 25000 engine
616 tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 7:29pm
Over the years, I've actually removed a couple of those bushings because the tractors clutch shaft was dragging and making it difficult to shift into gear without constant grinding of the gears. Removal of that bushing cured the problem.
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 8:11pm
Can't see much the bushing does with a good piolet bearing and pressure plate is rigged.                        MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(oh) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Jul 2023 at 8:14pm
Thank you. In that case I will just leave it out and put the new clutch in.
I’m sure others have thought about this and may have mentioned it. But if you ever wanted to record hours of Allis knowledge, Dr I would pay for it to happen!
