All-Crop Rebuild Pics Round 2
TomYaz View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 1:10pm
Originally posted by Rawleigh Rawleigh wrote:
Use an ag stub axle and hub like these.  Cut off the required length of the existing solid steel round axle, have your machinist counterbore it with an appropriate size hole, insert the stub axle and weld around it.  Simple and you have a high speed hub with modern components.  No change to frame of wheel placement.  Bolt the drive sprocket to the back of the new hub.
http://www.northerntool.com/shop/tools/product_200381465_200381465
http://www.northerntool.com/shop/tools/product_200369643_200369643
You can find them cheaper online elsewhere too.
Of course if you used the tractor spindle you could offset the wheels to the rear slightly to balance the machine (if you can offset the drive chain since you are doing a 66).
Great looking job though!!  I cannot wait to see the end result!!
Thanks.  It will be a while...I am going to put some more pieces of the frame on this weekend.
On those axles....Im not sure those are high speed (not specified on the link)
I have seen similar versions elsewhere but had limits on ground speed.
If I knew for sure my speed would be greater that would be a possible replacement.
But for this first one Im not going there as I am losing my shirt on this one already.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 1:50pm
Update: Called the manufacturer (real close where I used to live in IN) And that axle/hub
is slow speed only <20MPH.....
Edited by TomYaz - 21 Dec 2010 at 1:51pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 2:44pm
If you went with new axles & hubs I'd be looking at the trailer parts market for those kind of items.  Those would of course be highway speed items, easy to find replacement parts for and easy to find rims that fit and good tires.  Mike
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Rawleigh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 4:33pm
They do make high speed stub axles for trailers even if those aren't.  You don't have to do it for this one, just a thought to file away for later.
Some cheaper high speed options:
http://www.trailerpart.com/spindles.htm
Edited by Rawleigh - 21 Dec 2010 at 4:35pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 21 Dec 2010 at 5:03pm
Yeah I was just there...looks promising.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 7:00am
Did some research looks like the type 42 spindle has the best chance of working..
then it occurred to me..
Um, how am I going to drive the reel?
I guess I would have to drive the wheel of perhaps the sickle drive pulley..
ALinIL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 10:17am
Tom
On the Axle issue.  You might try this outfit.  They offer axles, hubs and bearing kits at good price.  Also If you ask they can probably supply axle of a slightly longer length at a reasonable price.  As for reel drive, I can't help as I do not have a machine here to mock-up pieces to fit. - AL
Edited by ALinIL - 22 Dec 2010 at 10:20am
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 10:29am
Originally posted by ALinIL ALinIL wrote:
Tom
Thanks Al.
a question I have....If you look at the drawing on that page, I have a question about measurement "A"...I need to know the total distance from the far end of the spindle  to
the outer edge of the hub facing after the hub is installed... they dont provide that info..It cant be too short....I suppose I should call. .... but they dont have a 2" shaft as I need...
Edited by TomYaz - 22 Dec 2010 at 10:34am
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALinIL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 4:22pm
Tom
I agree, more info is needed.  But I believe they have the capability to provide a longer and larger spindle.  They also have hubs(6 bolt) that may fit your rims.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rawleigh Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 6:31pm
Tom:  I heed to take a picture of the drive on my Massey Ferguson 33 planter hubs.  They use a modern style hub with a bolt on extension tube that moves the drive sprocket inboard enough to clear the tire.  Pretty simple and cheap solution.  Wish I had taken pictures while I had it apart last month replacing the axle bearings.  I do have the parts manual at the farm and I will try to get you a picture.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 8:14pm
Thanks Rawleigh...but just remember every proposed solution has to be relatively cheap and repeatable...
Post Options Post Options   Thanks (0) Thanks(0)   Quote TomYaz Quote  Post ReplyReply Direct Link To This Post Posted: 22 Dec 2010 at 8:15pm
Tom
Good to know...thanks
