All-Crop Rebuild Pics Round 2 |
Page <12 |
| Author | ||
TomYaz
Posted: 21 Dec 2010 at 1:10pm |
Thanks. It will be a while...I am going to put some more pieces of the frame on this weekend.
On those axles....Im not sure those are high speed (not specified on the link)
I have seen similar versions elsewhere but had limits on ground speed.
If I knew for sure my speed would be greater that would be a possible replacement.
But for this first one Im not going there as I am losing my shirt on this one already.
| Sponsored Links | ||
TomYaz
Posted: 21 Dec 2010 at 1:50pm |
Update: Called the manufacturer (real close where I used to live in IN) And that axle/hub
is slow speed only <20MPH..... Edited by TomYaz - 21 Dec 2010 at 1:51pm |
Skyhighballoon(MO)
Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
Posted: 21 Dec 2010 at 2:44pm |
If you went with new axles & hubs I'd be looking at the trailer parts market for those kind of items. Those would of course be highway speed items, easy to find replacement parts for and easy to find rims that fit and good tires. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Rawleigh
Joined: 14 Sep 2009 Location: White Stone, VA Points: 421 |
Posted: 21 Dec 2010 at 4:33pm |
They do make high speed stub axles for trailers even if those aren't. You don't have to do it for this one, just a thought to file away for later.
Some cheaper high speed options: http://www.trailerpart.com/spindles.htm Edited by Rawleigh - 21 Dec 2010 at 4:35pm |
TomYaz
Posted: 21 Dec 2010 at 5:03pm |
TomYaz
Posted: 22 Dec 2010 at 7:00am |
Did some research looks like the type 42 spindle has the best chance of working..
then it occurred to me..
Um, how am I going to drive the reel?
I guess I would have to drive the wheel of perhaps the sickle drive pulley..
ALinIL
Joined: 20 Sep 2009 Location: Frankfort, IL Points: 316 |
Posted: 22 Dec 2010 at 10:17am |
Tom
On the Axle issue. You might try this outfit. They offer axles, hubs and bearing kits at good price. Also If you ask they can probably supply axle of a slightly longer length at a reasonable price. As for reel drive, I can't help as I do not have a machine here to mock-up pieces to fit. - AL
Edited by ALinIL - 22 Dec 2010 at 10:20am |
TomYaz
Posted: 22 Dec 2010 at 10:29am |
Thanks Al.
a question I have....If you look at the drawing on that page, I have a question about measurement "A"...I need to know the total distance from the far end of the spindle to
the outer edge of the hub facing after the hub is installed... they dont provide that info..It cant be too short....I suppose I should call. .... but they dont have a 2" shaft as I need... Edited by TomYaz - 22 Dec 2010 at 10:34am |
ALinIL
Posted: 22 Dec 2010 at 4:22pm |
Tom
I agree, more info is needed. But I believe they have the capability to provide a longer and larger spindle. They also have hubs(6 bolt) that may fit your rims.
Rawleigh
Posted: 22 Dec 2010 at 6:31pm |
Tom: I heed to take a picture of the drive on my Massey Ferguson 33 planter hubs. They use a modern style hub with a bolt on extension tube that moves the drive sprocket inboard enough to clear the tire. Pretty simple and cheap solution. Wish I had taken pictures while I had it apart last month replacing the axle bearings. I do have the parts manual at the farm and I will try to get you a picture.
TomYaz
Posted: 22 Dec 2010 at 8:14pm |
Thanks Rawleigh...but just remember every proposed solution has to be relatively cheap and repeatable...
TomYaz
Posted: 22 Dec 2010 at 8:15pm |
Good to know...thanks
Page <12 |
