All Crop grain drill |
only AC orange
Joined: 06 Dec 2014 Location: Eastern Indiana Points: 554 |
Topic: All Crop grain drillPosted: 31 Oct 2025 at 8:40am |
Needing repairs for 18 hole All Crop grain drill - specifically, 2 seed cases. that is what meters the seed into the seed tube and then in to the ground. Previous owner apparently used screw driver or chisel to remove degree and punctured case. Thanks
Simon2
Posted: 01 Nov 2025 at 7:07pm |
Assume these housings where same on all drills ? Have a mounted parts drill, will check condition
only AC orange
Posted: 02 Nov 2025 at 6:32am |
I am also assuming they are all the same?? I need to replace 2 of them if you have. Thanks
im4racin
Joined: 12 Jun 2017 Location: Garrison ND Points: 1079 |
Posted: 02 Nov 2025 at 6:46am |
There is a couple different opener housings. Better post a picture
Edited by im4racin - 02 Nov 2025 at 6:47am |
only AC orange
Posted: 14 hours 35 minutes ago at 5:28pm |
According to my All Crop drill parts book, there are some superseded numbers but no change in seed case. The most recent part number is 339944. Does anyone have 1 or 2 of these? I would take picture but drill isn't here and I can't download anyhow. Thanks
Lon(MN)
Joined: 11 Sep 2009 Location: Merrill Wi Points: 2042 |
Posted: 2 hours 3 minutes ago at 6:00am |
Are you talking about the part that the square shaft runs through?
Edited by Lon(MN) - 2 hours 2 minutes ago at 6:01am |
http://lonsallischalmers.com
only AC orange
Posted: 42 minutes ago at 7:21am |
Yes sir! That part meters the seed that goes down thru seed tube and into the ground.
