All Crop 60A |
Page <12 |
CrestonM
Joined: 08 Sep 2014 Location: Oklahoma Points: 8457 |
Thanks(1)
Posted: 21 Jun 2024 at 11:07am |
That looks like the original 1936/37 model combine, called the All-Crop Harvester (no model number). Sad condition, but uncommon nonetheless. There would be some parts interchange with a 60A, but not many.
Edited by CrestonM - 21 Jun 2024 at 11:07am |
CrestonM
Thanks(1)
Posted: 21 Jun 2024 at 11:10am |
I use this website http://www.vbeltguys.com/ They cross reference Allis part numbers, and they're cheap. I've been running their belts on one of my 60A's for 8 years with no issues.
CrestonM
Thanks(1)
Posted: 21 Jun 2024 at 11:17am |
Not many differences that I know of. The grain bin has slightly more capacity due to it having a V shape in the bottom of the bin to accommodate an auger to convey grain to the unloading auger. Previous 60s just had a sloped bin floor to funnel grain into the unloading auger. 60As also have a lever actuated jaw type clutch to engage the unloading auger, where the 60s had a knob that must be turned to engage a dry disc clutch, and they notoriously slip when worn. A 60A brochure says they improved the cylinder/header drive gearbox on the 60A, but I don't know what that entails.
55allis
Joined: 30 Jun 2020 Location: Griswold Iowa Points: 1127 |
Posted: 14 Oct 2024 at 6:29pm |
So I’m running a grain cart for my brothers and sure enough I found another possible all crop in a creek.
Reason I say possible all crop is because im thinking it’s the older style round back…. Will get pictures as so as I can but getting too dark now. |
55allis
Posted: 14 Oct 2024 at 6:46pm |
55allis
Posted: 14 Oct 2024 at 6:47pm |
55allis
The second picture is the rest of the first one I found…
55allis
Posted: 14 Oct 2024 at 10:20pm |
Could someone post a picture of the “screens” and what location to find them?
Just thinking that maybe one of the two maybe has a screen still and I’m not quite sure what they look like… I don’t have any for the good combine (I think it did oats last it harvested). |
wjohn
Posted: 22 Oct 2024 at 7:35pm |
Yep, that looks like two of the earlier combines. Someone must have really hated them or they survived a tornado.
If there is a perforated sieve/screen, it will be basically at the bottom of the RH rear stack of racks at the rear of the combine. Stand outside looking down the straw rack (sideways/across the combine) and then go down to the bottom of all the racks/trays. There may be a removable one at the very bottom - or there may not. They are commonly removed or some crops like oats didn't require an additional screen. I wonder if the screens are the same size as used in the later All-Crop 60, 66, and 72?
55allis
Posted: 23 Oct 2024 at 1:49pm |
I wonder if the clean grain buckets will interchange?
Also the pto? |
55allis
Posted: 14 Dec 2024 at 5:33pm |
I got a chance to work on the engine (b125) and got the pan off…
It looks pretty good on the bottom side after slipping 2 gallons of water/oil out. So now the fun part of removing the sleeves…. Any advice? |
55allis
Posted: 14 Dec 2024 at 10:12pm |
I got 2 sleeves to come out!!
CrestonM
Posted: 18 Dec 2024 at 10:06pm |
I have an odd request...would you be able to get the serial off this combine? It's in front of the grain bin stamped on top of the angle iron frame. There aren't many of these 1935-1937 All-Crop Harvesters left, and I haven't seen a 1935 model to date, and only two 1936 machines. Several 1937s, however. Very cool that you have two of them there, even if the condition is poor.
Edited by CrestonM - 18 Dec 2024 at 10:07pm |
CrestonM
Posted: 18 Dec 2024 at 10:11pm |
The tailings elevator chain should interchange, definitely not on the clean grain elevator chain, however. They are larger buckets on the early model. I don't believe the pto will interchange either, or at least not easily. I know the slip clutches are different, as well as the way they attach to the gearbox. You could possibly modify the shaft to work, just depends how much time you want to spend.
55allis
Posted: 18 Dec 2024 at 10:55pm |
I’ll see what I can do…
55allis
Posted: 11 Jan 2025 at 6:46pm |
What are the specs on the rod bearings and main rod bearings?
I want to make sure they are standard so I get the right ones the first time. I’ve got 3 sleeves out plus an ER visit yesterday and things are looking good on the block, I haven’t found any cracks yet. The last sleeve (cylinder number 2) is broken up from water freezing and is being very stubborn to remove. I’ll most likely have to replace that rod from beating around it. The ER visit was because I was hammering that sleeve and something slipped (I think the piston broke loose) and the hammer ended up on my left thumb, it popped my nail pretty much off and I thought I had broke the tip but it didn’t… Praise the Lord!!!
55allis
Posted: 21 Mar 2025 at 11:48pm |
It’s been awhile since a update but I have been working on it every time I get a chance…
I did get all the sleeves to remove and I got the valves off the head, ended up shattering a valve guide but noticed another was broken before (never seen that before). Did get them to come out though. Need your advice, do I go ahead and replace all the valve guides or just the two that are broken? I’m putting all new valves if that makes a difference… Also found that a Kohler K321 intake valve is very close to the b125’s, found that kinda interesting. |
Mikez
Posted: 22 Mar 2025 at 7:10am |
Glad I’m not the only one thats looking in the woods when operating tractors.
I had thought I seen one but don’t think it’s a all crop.
Page <12 |
