air filter placement
alan-nj View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alan-nj Quote  Post ReplyReply Direct Link To This Post Topic: air filter placement
    Posted: 07 Jan 2015 at 9:44am
i'm intending to change the oil bath filter on my wc to a dry k&n mounted behind the 464 body  carb.......any pros and cons to mounting directly at carb, or use a piece of pipe (what length?)   between carb and filter.......
blue924.9 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote blue924.9 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 10:37am
NOOOOOOOOOOOOOOOOOOOOOOOOOOOO!!!!!!!!!!!!!!!!!!!!!!!  dont use a k&n, they have a known history for letting air that is unfiltered and pure dust get past them.
hi my names dan, I am a young guy. i have a problem, i prefer my tractors orange and my clutches mechanical, thanks for letting me share
cwhit View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote cwhit Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 6:33pm
 Alan, you want to mount the filter where it will recieve the coolest air posible.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jan 2015 at 7:45pm
Above the hood is best, but if you use a metal tube that is bent by a tailpipe bender with a pinched corner.......I don't know how good that is. Smooth mandrel bent piping as larger or larger diameter than the carb inlet is best. K&N filters are fine when oiled properly.
This page was generated in 0.199 seconds.
