aetna clutch release bearing |
tractorboy ![]() Silver Level ![]() Joined: 03 Oct 2009 Location: southern Va Points: 474 |
![]() ![]() ![]() ![]() ![]() Posted: 01 Mar 2023 at 9:23pm |
I know it's new & packed tight with grease, but I can hardly turn this throw-out bearing by hand.
DrAllis ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Points: 21848 |
You have it pressed onto the shifter sleeve ?? or are holding it in your hand trying to turn it ??
in my hand
I think I'd assemble it and give it another turn test.
Ok I pressed it onto the shifter sleeve and the rear part of the bearing turns fine. I didn't realize on a throw out bearing there are two bearings. The front thrust face is the one that is tight. maybe the pressure of pushing against the release fingers will make it turn, thanks keith so.va.
