advice on splitting a 6080
Tom Feldpausch View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Feldpausch Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 7:58pm
DrAllis (Dan),
I think I've got it now. Once the two tractor halves are realigned, then do you spin the headless bolts/pins out to the rear, and replace with original bolts? Just want to make sure I have it.
Thanks!
TF
Edited by Tom Feldpausch - 09 Jan 2019 at 8:10pm
Lynn Marshall View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lynn Marshall Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 9:30pm
Yes, that's what you want to do. Those are metric bolts by the way.
H Clark View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote H Clark Quote  Post ReplyReply Direct Link To This Post Posted: 09 Jan 2019 at 9:37pm
I would take a grinder with a cutoff wheel and cut a slot in the end of the bolt/ line up pin after you cut the head off so you can use a screwdriver to back them out.
1960 D-12,1948 WC, 1973 160, 1977 175, 1984 6060
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Feldpausch Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 7:43am
Hi Walter,
What did you put the ViseGrips on the PTO for?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tom Feldpausch Quote  Post ReplyReply Direct Link To This Post Posted: 17 Jan 2019 at 7:46am
Great idea, Holly. We milled a hex on the cut off bolt ends on ours for a 17 mm socket. We'll see how that works.
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 18 Jan 2019 at 6:36pm
Put visegrips on pto to turn it .With pto and gears engaged and clutch released you can turn pto and roll tractor .Mechanical engaged pto.
