advice on splitting a 6080 |
Page <12 |
Tom Feldpausch
Joined: 05 Aug 2013 Location: Hastings, MI Points: 150 |
Posted: 09 Jan 2019 at 7:58pm |
DrAllis (Dan),
I think I've got it now. Once the two tractor halves are realigned, then do you spin the headless bolts/pins out to the rear, and replace with original bolts? Just want to make sure I have it. Thanks! TF
Edited by Tom Feldpausch - 09 Jan 2019 at 8:10pm |
Lynn Marshall
Joined: 13 Sep 2009 Location: Dana, Iowa Points: 2427 |
Posted: 09 Jan 2019 at 9:30pm |
Yes, that's what you want to do. Those are metric bolts by the way.
H Clark
Joined: 11 Jul 2010 Location: West Virginia Points: 404 |
Posted: 09 Jan 2019 at 9:37pm |
I would take a grinder with a cutoff wheel and cut a slot in the end of the bolt/ line up pin after you cut the head off so you can use a screwdriver to back them out.
1960 D-12,1948 WC, 1973 160, 1977 175, 1984 6060
Tom Feldpausch
Posted: 17 Jan 2019 at 7:43am |
Hi Walter,
What did you put the ViseGrips on the PTO for? |
Tom Feldpausch
Posted: 17 Jan 2019 at 7:46am |
Great idea, Holly. We milled a hex on the cut off bolt ends on ours for a 17 mm socket. We'll see how that works.
wfmurray
Joined: 13 Sep 2009 Location: Bostic NC Points: 1225 |
Posted: 18 Jan 2019 at 6:36pm |
Put visegrips on pto to turn it .With pto and gears engaged and clutch released you can turn pto and roll tractor .Mechanical engaged pto.
Page <12 |
