Adjusting WD45 WFE
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Topic: Adjusting WD45 WFE
    Posted: 26 Jun 2010 at 4:42pm
What is the procedure for moving the tie rod ends outward? I removed the bolt and spread the clamp near the wheel, placed a small hydraulic jack between center of tractor and steering lever on outer spindle, but it does not want to move. Some help from the ranks of "The Orangemen" would be appreciated.
Why is there never time to do it right the first time, but always time to go back and fix it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 4:52pm
There was a post about this a couple weeks ago. I think the answer was some heat.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 4:55pm
Get the trusty old torch out and put the heat to it. After you get it moved out put some anti seize on them then the next time you move the front in or out it will slide right out. Don
Edited by Don(MO) - 26 Jun 2010 at 5:32pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2010 at 6:06pm
Thanks fellas.  Heat it shall be!  I was concerned there might be some threads somewhere inside.
