Adjust clutch pedal
Sitesstables View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Sitesstables Quote  Post ReplyReply Direct Link To This Post Topic: Adjust clutch pedal
    Posted: 03 Jun 2010 at 6:00am
Need to now the proper length or how to adjust the cluct pedal on my WD.. As of now it works but is all the way on the foot rest.. need to know how far out it should be from the foot rest..
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 05 Jun 2010 at 7:50pm
it should not go all the way to the toe plate.there is a protruding stop on the side of the transmission case that stops the pedal before it reaches the toe plate.the deminsion  from the stop is 1/2-to 1 inch before it contacts the throwout bearing.a lot of these stops are broken off...
