Added another 6080
rrhead(SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Topic: Added another 6080
    Posted: 27 Feb 2011 at 8:51pm
We added a 1984 6080 to the stable yesterday. Came from Missouri and does need some work. Runs real well. This one goes with our 1980 6080 FWA and no cab. And my 1984 6080 2wd with cab. Great little tractor and very handy. rrhead(SD)
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 9:23pm
Looks like it has potential.  I've seen worse.
D17 owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D17 owner Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 9:47pm
^^ He said it I seen alot worse. Looks like it would clean up good with a goo wash.
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2011 at 10:56pm
I like the ghost effect of multiple decals.  Was this changed on the lot in 85 or what?  Wonder if there is a story or if it's as simple as being a victim of  Deutz changes.
karl f
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 3:43am
There  ok if you keep em wound up ,and seems like they are out of balance - front to heavy - mine will just set and spin- its real aggrivating -  good for working in hay, I,ll take a 180,185 any day over them though
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 6:47am
This one will replace our 180 that's getting bad at jumping out of 3rd and 4th gears. Hope to fix up some day. Plan on fixing the decals somehow. Need a front grill, too. Our FWA 6080 hardly ever spins. It's never been stuck as long as we've had it. Been in cattle yards where front wheels have been over half way covered. rrhead(SD)
Byron WC in SW Wi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Byron WC in SW Wi Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 7:06am
When the 6000 series came out with the new style cabs and the old style sheet metal I thought they were the best looking tractor ever with that setup.  Still are a great looking tractor.
I didn't care for how the four post ROPS looked compared to the two post canopy on the 100 series.
BStone View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BStone Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 7:14am
I've got a 6060 fwa with loader and it's been one of the best tractors I've ever had.I have 2 185's and there good tractors but the 60 series are so much more useful for me.What kills the 185's is the pto when shredding.I want let the younger people use it after one ran over a small tree while trying to use the breaks and panicked when it wouldn't stop with the breaks.
orangeonly View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeonly Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 9:02am
rr, does your FWA HAVE WEIGHTS ON THE FRONT?
Ours does and all four tires are loaded. I'm thinking it's too heavy in the front.
BLee Mn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BLee Mn Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 10:01am
Rod i see you got a big Boy sittin in the back of shed
Cowboy UP
Post Options Post Options   Thanks (0) Thanks(0)   Quote rrhead(SD) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 1:08pm
No weights on the front. No weights on the back, but tires are loaded. Brian, that's my nephew's 4 dub. He's had to spend alot of money on it. But it runs fine now. He likes his 8550 with Cummins in it better. Thanks for the responses. rrhead(SD)
Edited by rrhead(SD) - 28 Feb 2011 at 5:38pm
This page was generated in 1.094 seconds.
