Adapters for 3 point lift arms
Lance/SC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Topic: Adapters for 3 point lift arms
    Posted: 25 Apr 2010 at 11:53am
Looking for two adapters that mount to the top of lift arms in order to hook to lift latches without having to straight bolt them to the rock shaft arm.  (hope this makes sense) It's for a CA.  Thanks
NCAllisnut View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 12:16pm
Like the ends on plow lift arms that you could adapt to your lift links?
Adam
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 1:14pm
Do you have the proper CA Lift latches? if so, there is no adapter to mount the lift latch, it pins to lift arms. If you do not have lift latches I'm not sure what else was available to pint o those.
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 1:36pm
Do you have a snap coupler CA or are you converting a pin-hitch CA? If you have a pin-hitch CA then to install snap-coupler lift latches you will either have to cut off the ends of the rock shafts or replace the rock shaft with one from a snap-coupler CA. The lift latches then just bolt to the rock shaft.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 3:24pm
I think he is trying to make the lifting links for a 3 point adapter that would attach to the lift latches.  Maybe I'm worng, but that's how I read it.
Adam
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 4:43pm
 The name I couldn't think of was the lifting links on the 3 point adapter.  These bolt to the lift links and the other end has the SC pins that go in my SC lift latches.  I have the correct rock shaft and latches.   I saw this set up on a CA at the GOTO yesterday.  Thanks Adam.
Post Options Post Options   Thanks (0) Thanks(0)   Quote NCAllisnut Quote  Post ReplyReply Direct Link To This Post Posted: 25 Apr 2010 at 8:02pm
Are you looking for the factory 3 point adapter vertical pieces, or are you trying to make your own?
Adam
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 1:52am
I think he is talking about the top pieces shown here:
http://secure79.elinuxservers.com/~tractor/catalog/product_info.php/cPath/24_25/products_id/54?osCsid=c5b759c51243d697428c74be2f06e477
Edited by Rfdeere - 26 Apr 2010 at 1:54am
http://www.rumelyallis.com
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 4:50am
I have a used pair of them I'd sale for $60.00 + the trip.
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lance/SC Quote  Post ReplyReply Direct Link To This Post Posted: 26 Apr 2010 at 7:05am
Thanks, RFDeere, thats exactly what I need.  I will be calling Jim about something else today and will touch base with him about these.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Apr 2010 at 7:42pm
Lance I sent you a PM.
Thanks, Don
