AC190xt How to set static lift height for mowing |
Post Reply |
whizone
Bronze Level Joined: 23 Mar 2018 Location: Texas Points: 97 |
Posted: 20 hours 37 minutes ago at 8:04pm |
All, I have a 65' Allis Chalmers 190xt which I have been doing a lot of mowing/ bush hogging with. My cutter is a 3pt attached mower. Can anyone tell me how to set the lift to a static height? I am wearing myself out raising it to avoid obstacles and then fighting to get it back to the correct cutting height. Your thoughts are appreciated. Thanks much.
Edited by whizone - 20 hours 30 minutes ago at 8:11pm |
Orange Level Access Joined: 12 Sep 2009 Points: 20165 |
One of the two rear levers on the console is a "Position Control" lever that sets the minimum height for the 3-point hitch arms. Looking at the paint job, I imagine there aren't any decals on those levers. If the position Control linkage isn't froze or broken, it will do exactly what you want and still allow you to raise to go over things and lower right back down to the height you desire.
whizone
Thanks so much Doc, I was not sure how to get it adjusted. I will see if it is connected and works.
PaulB
Orange Level Joined: 12 Sep 2009 Location: Rocky Ridge Md Points: 4652 |
If you had an operators manual and had also read and understood it along with the manuals pictures, you would know how all of your tractor's functions were operated.
KJCHRIS
Orange Level Joined: 21 Dec 2015 Location: WC Iowa Points: 873 |
The position control should be the rear lever closest to seat. The other lever is Traction Booster/draft control.
Run tractor with 3 pt lift arm lever. FYI lever has 4 positions; 1 lift, 2 hold, 3 T B, 4 lower. Run tractor, set 3 pt lever in "TB" position. Move Position Control lever (rear LH) to get mower set at desired height. Leave the T B lever (rear R H) in its furthest down position. After that run tractor with 3 pt. lever in T B position while mowing, use the 3 pt lever to raise and lower as needed.
Post Reply | |
