ac130 belt
brucea View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote brucea Quote  Post ReplyReply Direct Link To This Post Topic: ac130 belt
    Posted: 06 May 2015 at 11:57am
is anyone else having problems with models breaking belts on my 5th one in two years dealer says they can find nothing wrong with it only cut about half acre of grass
Post Options Post Options   Thanks (0) Thanks(0)   Quote jaybmiller Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2015 at 6:21am
Has to be an 'alignment' issue. ANY rider/mower will bust belts if the belt doesn't run properly. It should run 'flat against the 'flat' pulleys, near center if possible AND at 'right angles' as well. Anything 'bent' even a little will cause a problem.
You may need a few 'extra' eyes to see what's really wrong.Look from both side of the tractor,have someone slowly turn the blades to see how the belt moves. If electric PTO, do not engage at full speed! The 'shock' can 'yank' the belt,hit a pulley 'wrong' and nick the belt, Do that a few times.....whamm, busted belt. Also check the deck to be straight and plumb. Again this is an 'alignment' thing. Whacking tree roots a few times can bend the deck and or mounts juuuust enough to throw off proper alignment.
Knowing what belts cost, take a day or more to see WHY it's happening, might only take 10 minutes with a hammer to re-align the culprit.
hoping this helps
Jay
Post Options Post Options   Thanks (0) Thanks(0)   Quote brucea Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2015 at 9:41am
thanks that is what i was thinking been looking at that   they told me to engage the mower full throttle seemed to me alot of strain on the belt
farmtoybuilder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmtoybuilder Quote  Post ReplyReply Direct Link To This Post Posted: 13 May 2015 at 10:43am
They're Nuts to tell you that!!! Never engage them running much above idle! Shock load snaps them into!!!!
Roach View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roach Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 9:08pm
I agree they are nuts. especially if it is colder temps....
1937 WC, 1948 G,1954 CA,1956 WD45, 1967 D17, 1937 M crawler, 1963 D-19, 1966 190XT, 1967 D-15, 1948 HG42 Cletrac, 1955 G456 Terra Trac, CAT 10 1928 and CAT 22 1938
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 07 Jun 2015 at 11:08pm
make sure you are putting onthe proper lenght to tight breaks  them also   make sure all the spring loaded idlers move proper because as the deck goes through alow spot the distance is longer between pulleys  i would look at pulleys pivot points
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Sep 2015 at 8:42pm
what size belt goes on the 46" model? The manual does not tell me
Charlie
NorthernChill View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NorthernChill Quote  Post ReplyReply Direct Link To This Post Posted: 01 Jul 2017 at 9:30am
Simplicity 1719911SM
V-BELT HA 117.0 AR runs about $35.00 to $40.00
I dont know if there is a cheaper belt that you can use but if there is let me know
This page was generated in 0.049 seconds.
