AC wagon or running gear
Stockman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stockman Quote  Post ReplyReply Direct Link To This Post Posted: 03 Aug 2021 at 6:05am
I’ve enjoyed learning a little bit more about the Allis Chalmers’ running gear models. I came in to one quite by accident. When I got this home I found the ID tag under several layers of paint. Trying to learn more about it and want to try to bring it back to its original condition for use in hayrides. Not quite sure how I’m going to build it out. I am curious about what style/brand tires would’ve been original. Only two of the four wheel hubs have zerk fittings in the caps. Not sure if that’s original. Also one wheel was replaced. The stem comes out from the inside on that one. Any thoughts would be appreciated. Thank you – Ben
AC7060IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 11:50am
4847v
Stockman (Ben), your wagon gear’s ID tag reads, “cat no, 2013920” which corresponds to an AC 701 model. It’s ID’s other info reads, “serial 7 11933” corresponds to it being a 7 ton size with sequential number of 11933 which positions it near the beginning of its production run (11482-14042) which began in 1965ish or there about? I say that because it received the “newer AC triangle logo” decal which debuted in 1965.
The AC 701 gear could have been supplied with a number of tire/rim options. It's August of 1966 sales brochure list the following wheels(rims) sizes (Inch diameter x inch width) then probable tire sizes;
14 x 6, (G78-14s,8.5-14?)
15 x 6, (9.5-15?)
16 x 6.5, (7.5-16?)
15 x 8, (11-15?) flotations
15 x 10, (11-15,12.5-15?)flotations
15 x 5.5 (6.5-15?,7.5-15?)
Your grease zerk hubs would have been an add-on as I don’t believe that to be original.
All hubs & wheels should include a common “EWC” stamped ID.
EWC Q709 is their hub ID.
Their spindle size is 1 3/4” welded into their frames. The Q709 bearings are as follows;
1 3/8” LM48548/LM48510,inner
1 1/4” LM67048/LM67010,outer,
N41461S(National), CR 15190(Chicago Rawhide), 901283, hub seal.
Edited by AC7060IL - 25 Dec 2024 at 11:30am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stockman Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 1:51pm
Appreciate that information! I did build it out and currently have the same wheel configuration as when I bought it. If I ever have to change the tires I’ll probably double back on the wheel question. Thanks again for the input
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 23 Dec 2024 at 6:09pm
Nice!  Thanks for sharing the pic!  Stockman is correct, I never saw any hubs with zerks.  Those would be an add on or a replacement. Not original.    Luv seeing these wagon gears brought back to life!  It is appreciated!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 3:47pm
Appreciate that information! I did build it out and currently have the same wheel configuration as when I bought it. If I ever have to change the tires I’ll probably double back on the wheel question. Thanks again for the input.
5292v
You're welcome Ben. Congratulations on your nice AC 701 wagon build. Is it setup as a people hauler? Here is a photocopy of the 701's spec sheets per its 1966 brochure. It list most of it's wheel options.
Edited by AC7060IL - 26 Dec 2024 at 3:50pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stockman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 7:36pm
Yes, a people hauler. Kept under cover except the month of October.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stockman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 7:37pm
My pleasure! Glad everyone appreciates it as much as we do.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stockman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 7:38pm
Thanks for posting that spec sheet too!   Much appreciated AC7060IL!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 9:16pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stockman Quote  Post ReplyReply Direct Link To This Post Posted: 26 Dec 2024 at 9:33pm
Very interesting! Thanks for posting
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 6:45pm
Mikez, Thank you very much for sharing your AC dealership’s 1969 wagon list sheets. That is fantastic! 5542v
Edited by AC7060IL - 27 Dec 2024 at 6:47pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mikez Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 7:06pm
Your welcome.
Can you read it ok.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Dec 2024 at 7:15pm
Your welcome.
Can you read it ok.
Yes
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC7060IL Quote  Post ReplyReply Direct Link To This Post Posted: 22 Nov 2025 at 12:00pm
I’ve been studying Mikez’s 1969 EWC Quincy IL Farm Wagon price list offered to AC dealers.
Trying to figure customer’s final charge for a new 1969 AC 701 gear. Assume in 1969 that a set of four 14” implement tires may have cost $80(20ea)? If so, then a 1969 dealer may have had the following fees associated with it;
AC 701 gear @ $262,
Shipping from Quincy @ $50 ?
Set of tires @ $80 ?
Shop labor assembly @ $40 ?
69’ shop labor @ $10/hr,
Dealer’s total cost : $442. ??
What do you think?
Edited by AC7060IL - 22 Nov 2025 at 12:01pm
