AC HD-10 W Restoration Help
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Jun 2014 at 10:32pm
inside the release bearing housing is a bushing that could be froze to the shaft.  it is inside the three arm yoke that pushes on the cams to make them tighten onto the driven disk.  the back of the yoke rides in the bearing and it rotates with the flywheel.  the shaft must be free inside of it to function
Post Options Post Options   Thanks (0) Thanks(0)   Quote DiyDave Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2014 at 5:20am
Originally posted by Real_TL Real_TL wrote:
Well just an update, We got her back together, gauges installed, New blower on and she moves on the rear steering clutches but I still need to get that master clutch free, Been spraying the cams and parts with a lot of wd40 hoping it will eventually come loose, should I heat it up and spray it? It is stuck locked in the open position i believe. I will post some more pics and a vid tomorrow night if all goes well.
WD40 is a lousy choice as a penetrating oil, I have no loyalty to any one product, but Kroil is 10 times better than WD40.  Some others include nutts off, PB Blaster, acetone/ATF mix. Any will out-do WD40!
Real_TL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Real_TL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2014 at 4:40pm
haha I agree but that's all I had here at the time, I go through a ton of pb blaster on my projects, I did get it freed up and its working, but now it looks like I need a radiator for it because it has sprung a few holes and looks like it has been fixed before where the fan had hit it, so now its time to search for that.
[TUBE]Allis Chalmers HD-10 w First run in over 30 yrs[/TUBE]
[TUBE]Allis Chalmers HD-10 w First run in over 30 yrs 2[/TUBE]
https://www.youtube.com/watch?v=NSmGUPLBUpk
https://www.youtube.com/watch?v=lCMJ2ISMtTc
JC-WI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JC-WI Quote  Post ReplyReply Direct Link To This Post Posted: 27 Jun 2014 at 11:59pm
Here , I will try to turn them into live links...
 Congradulations on getting her going again...Liked your vids... Liked all the pics you posted too.
