A-C D15 SII Oil to use in torque tube/power direct
snowman(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Topic: A-C D15 SII Oil to use in torque tube/power direct
    Posted: 12 Jun 2023 at 3:06pm
Simple question, what type of oil is supposed to be used in the torque tube where the power director resides?  I don't have an operators manual and the service manuals doesn't have any of this information.  I remember seeing on a post somewhere that there were people using different types of oil, and it was suggested to continue using what was used in the past.  I'm a second or third owner of this tractor purchased off a used lot.  If you have the oil capacity as well for the torque tube/power director chamber that would be helpful too.  Getting ready to slide the two halves back together after replacing some broken power director parts and need to get some oil.
Thanks for the help on this.  A-C D-15 SII tractor.
1950 WD, 1966 D-10 III, 1961 D-10 II, 1966 D-15 II Gas, A-C Minibike, 917 Hydro Mower, 917 Hydro Blower w/cab, West Michigan "Allis Express"
orangeman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 3:25pm
Snowman: Per AC Service Bulletin S-1493 the D15 tractors both Series I and Series II take 9 quarts of 20 weight ML spec. or its equivalent.
~ Orangeman
Edited by orangeman - 12 Jun 2023 at 3:26pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote orangeman Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 3:49pm
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 3:54pm
AGCO 821 or equivalent works well too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Jun 2023 at 10:21pm
A universal trans/hydraulic oil  will do fine.
KJCHRIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KJCHRIS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 12:04am
Op Man'l says 20w, change 2 times / year.
 If you have other newer tractors use what you put in their hydr / tran. Or Something that's equivalent to AGCO 821 fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 6:31am
All lubricants have improved over the decades since that owners manual was printed. 20W non-detergent oil was what they had then and it worked.  Modern day Hy-Tran/ Hy-Gard/ Universal Trans/Hydraulic/ AGCO PermaTran/AGCO 821XL all work and are a 10W-30 viscosity. No Company rewrites a 50 year old owners manual. You just have to figure it out and take advice from those who know what now works.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 7:22am
Thank you for the feedback, still pondering which way to go on this.  Non-detergent 20W oil is hard to find locally, I called an AGCO dealer and they have a regular version of the AGCO Permatran 821 (at $138 for 5 gal pail which is a semi synthetic) and Permatran 821XL that is for CVT transmissions.  Or I can cheap out, with an 821 equivalent at Tractor Supply.
Cost isn't a driving factor, but purchasing something that works best and doesn't eventually leak out of gaskets and o-rings is my concern.  Straight 20W vs 10W-30?  Just looking for a few more opinions on this.
Jim.ME View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim.ME Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 7:34am
An 821 equivalent is going to be better than the 20W weight non-detergent of years ago and cost effective.
As for finding an oil/fluid that won't eventually leak out of gaskets, O-rings and seals; I see that as more of an issue with the gaskets, O-rings, and seals, than the oil/fluid you use, since whatever you use should be in the same weight range as the 20W weight.
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 9:20pm
Like DSERIES4 says, I've always used AGCO 821 for several years now.  No issues so far.  Good Luck!
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 13 Jun 2023 at 11:06pm
modern transmission hydralic  oil is what you would get if it was at our shop  , sludge and crud in engines and transmissions is almost a thing of the past even with poor maintanace
WF owner View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WF owner Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 5:36am
Oils/fluids have evolved over the years. I am betting, if the equivalent of AGCO 821 Power Fluid had been available when your D-15 was built, it would have been the recommended fluid.
Post Options Post Options   Thanks (0) Thanks(0)   Quote snowman(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Jun 2023 at 6:19am
I went with the Permatran XL.  Thanks for the help.
snowman(MI)
This page was generated in 0.088 seconds.
