AC D 21 Hydralic oil getting in engine oil?
FORD GUY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote FORD GUY Quote  Post ReplyReply Direct Link To This Post Topic: AC D 21 Hydralic oil getting in engine oil?
    Posted: 28 Feb 2011 at 8:30pm
Bought a D21 series II last week that hasn't ran in 5-6 years.  Got it running and added about 6 gallons of hyd. oil to it, cleaned out the sediment bowls, and trailered it home.  I've been playing around with it and warmed it up good today to change the engine oil;  well, I pulled the plug and out came about 6-7 gallons of real thin oil.  This might explain why it was smoking so much.  I was concerned it might be coolant because it was white-gray diesel exhaust, but the coolant leval dosn't go down. Where are all the possible places hyd. oil could be entering the engine oil?  Does the D-21 have a dry clutch?
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 9:20pm
If it is hydraulic oil, it is coming from hyd. pump front seal.
 Does it smell like diesel fuel? Would rather thinl it is diesel fuel coming from inj. pump front seal.    MACK
Anthony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 10:20pm
What up Ford Guy......its sounds like a total loss to me, but being the good person I am I will trade you a NICE REAL NICE Case 120 riding mower for the ole wore out D21...and you wont have to worry about any leaks ever again....so what do you say....we got a deal.....this is going to be a hoot! Your a lucky man Ford Guy a lucky man!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Anthony Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 10:21pm
oh and by the way, glad your an Allis man now............
Post Options Post Options   Thanks (0) Thanks(0)   Quote FORD GUY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Feb 2011 at 10:54pm
It does not smell like diesel fuel, the seal on the hyd. oil pump must be the problem.  I guess thats the only place the hyd could be leaking to the engine?  Thanks Mack
