AC B
ACfanforever85 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACfanforever85 Quote  Post ReplyReply Direct Link To This Post Topic: AC B
    Posted: 10 Nov 2014 at 12:56pm
Just put new resistor on to step down the voltage to 6 volts. I am still getting 12 volts to my coil. Not sure what could be the problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACfanforever85 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2014 at 8:10pm
Anyone that might know what will fix my problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2014 at 8:12pm
Remove the coil and resister and buy a 3 ohm coil. Made to run 12 volts.
Edited by CTuckerNWIL - 11 Nov 2014 at 8:13pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACfanforever85 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2014 at 8:15pm
Do you think replacing the coil period, will fix my problem
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2014 at 8:19pm
You apparently have a 12 volt battery and an old 6 volt coil. Just buy a new coil made for 12 volt system and you will be fine. The distributor and point don't know the difference. Old coil and resistor is a patch job, will cause you problems over time... just get rid of it now.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2014 at 8:20pm
make sure the new coil says "12 volt with no external resistor ".
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2014 at 8:27pm
Your system now looks something like this ?  Change the coil and resistor to one unit new coil.
Edited by steve(ill) - 11 Nov 2014 at 8:28pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ACfanforever85 Quote  Post ReplyReply Direct Link To This Post Posted: 11 Nov 2014 at 8:32pm
Before I put the resistor on I had a ballast resistor and a 12 volt coil. The coil on there is probably 15+ years old
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Nov 2014 at 5:51pm
some coils say "needs external resistor" and some say "no external resistor needed..... for 12 volt systems.
This page was generated in 0.316 seconds.
