AC 8010
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Topic: AC 8010
    Posted: 29 Sep 2010 at 6:52am
Going to look at some 8010's in Ohio this weekend. Anything in particular you should check. Do not really need 4x4 but several setting around. Is the 4x4 a good design? Thanks, Bill
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 7:29am
Any 8000 series should be a good tractor. The front wheel assist shouldn't be an issue. In my opinion, the power shift is more desireable than the power director transmission. Sounds like there is more than one for sale. What kind of price on them?  Thanks, Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 8:44am
Two wheel drive 8010 one for 15,000 and one 19,500
Four wheel drive 23,000
Thanks for your reply, I have never sat in one, let alone work one. Bill
StewartMD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StewartMD Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 2:59pm
We have a 1984 w/ FWA and the 20 speed power director transmission.  In my opinion I would go with FWA.  You never know when you will need it but also alot depends on what you are planning on using it for.  I would recommend a powershift if you are traveling the roads often.  I personally prefer a 20 speed in the fields because it allows you to select the more appropriate speed, even with our 20 speed sometimes I wish I had more to choose from.  Ours has been a very reliable tractor.  We use it on the discbine, round baler, disk, manure spreader, silo blower, ag-bagger, etc.
8030, 8010, 220, 185, 160, D-17, WD, Unstyled WC, CA, G, 20-35, Gleaner E
wheatbreeder View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wheatbreeder Quote  Post ReplyReply Direct Link To This Post Posted: 29 Sep 2010 at 7:58pm
I have a 8050 power shift 12 speed it works fine. The power director can present issues under heavy load, under light loads the power director is good. The 8050 is used for primary tillage on a five shank Sanford wing plow.
Morley
Farm stuff 8050,6690,175,F2,5050,WD
