AC 715B - tie rod ends - and steering ? |
Coke-in-MN ![]() Orange Level Access ![]() Joined: 12 Sep 2009 Location: Afton MN Points: 41785 |
![]() ![]() ![]() ![]() ![]() Posted: 10 Jan 2025 at 11:05pm |
Need to replace tie rod ends - anyone have a interchange for the parts or a stock number
Also steering seems to wander , and as you correct it the steering wheel will eventually make a full turn just to keep going straight when roading machine . Have always thought it was in the steering control hydraulic steering sector , but know wonder if it's the actual steering hydraulic cylinder has internal leakage which causes the wander of machine . No problem at slow speed or when working machine turns fine and has power to turn wheels in sand, mud or such . Just this having to constantly correct when on road |
"Challenges are what make life interesting; overcoming them is what makes life meaningful." |
orangeman ![]() Orange Level ![]() Joined: 12 Sep 2009 Points: 1806 |
AC 715 Tie Rod Ends P/N's as follows:
Number Qty. Description 1007069 1 Rod End, Tie (Left Hand Thread) 1007070 1 Rod End, Tie (Right Hand Thread) Source - AC 715 Loader Backhoe Parts Catalog Form 9003463 12/75. Note this manual is an early manual so when the AC 715B came along - am wondering if there were any rolling engineering changes that would have been covered by a supplement. U.S. Manufacturers - Moog and Delphi Technology's - possibly Minn Parr HTH's ~ Orangeman
PDF file for the 714 / 715 AC Industrial - CDS parts list
Now just have to figure out how to convert numbers to industry suppliers https://www.tractorparts.com/PDFs/AC_710C_714C_715C_SN3301-7217_PARTS.PDF |
DiyDave ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: Gambrills, MD Points: 52926 |
You might try surplus center, looks like they have quite a variety, from 3/4" down...
Edited by DiyDave - 11 Jan 2025 at 3:41pm |
Dave - those are all rod end bearings , the ones used on this tie rod are automotive type and about 1" diameter threads . the stud is a tapered machined surface that wedges into spindle housing
steve(ill) ![]() Orange Level Access ![]() ![]() Joined: 11 Sep 2009 Location: illinois Points: 84230 |
Coke... if the get a couple dimensions, you might match up here..
![]() Edited by steve(ill) - 12 Jan 2025 at 7:58am |
KRAKMT ![]() Bronze Level ![]() ![]() Joined: 21 May 2010 Location: MT Points: 103 |
If anyone finds the correct ends I would Iike a part number, and if anyone sources new kingpins and bushings I really need to rebuild my hubs.
