Ac 7080 t handle
Kadyn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kadyn Quote  Post ReplyReply Direct Link To This Post Topic: Ac 7080 t handle
    Posted: 14 Oct 2023 at 1:18pm
I am looking at buying my great grandpas old 7080 that hasn’t been touched in 15 years I got it to run and drive in forward but can’t get the t handle to spin to get it in reverse. Any help would be nice
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 1:41pm
The twist is pushing/pulling a cable so you have to see why it's not moving. Probably the cable itself but you won't know till you get the tranny side disconnected.
SilverShoes View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote SilverShoes Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 3:18pm
Yup take your floor plate up and the side panel off the console and start following the push pull cable. 90% of the time it’s a tight cable. They shift easily if the cables are in going condition. They don’t last long enough though, especially if they can get moisture or dirt inside of them
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kadyn Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 4:22pm
Not what I wanted to hear but I will try it. Thank you
HudCo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote HudCo Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 8:31pm
thats alot cheaper than biulding a tranny
victoryallis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote victoryallis Quote  Post ReplyReply Direct Link To This Post Posted: 14 Oct 2023 at 8:46pm
Don’t force it
bigal121892 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bigal121892 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Oct 2023 at 10:19am
What did you want to hear? You have a tractor that is over 40 years old, has sat for 15 years, you are going to have to put some money into it if you want to use it. One of the first things you will want to do, is replace the front harmonic damper.
