Ac 7000 rear dipstick
Bassguide View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassguide Quote  Post ReplyReply Direct Link To This Post Topic: Ac 7000 rear dipstick
    Posted: 15 Jul 2020 at 1:17pm
So my 7000 never had the rear dipstick. I can't find one either. If you know where I might find this part I would appreciate it. If a fellow 7000 owner would give some measurements I can make my own, either solution works for me, just need to replace.....thanks
Tbone95 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 1:25pm
Are you referring to the oil fill at the top near the top link on the back of the tractor?
No dipstick there, you fill oil there until it's between the 2 sight glasses, lower left side of rearend.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 1:28pm
Tbone, I think a 7000 is different than the rest of the 7000 series. Been a long time since I've been around any straight 7000 though.
Edited by Lonn - 15 Jul 2020 at 1:28pm
Wink
I am a Russian Bot
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tbone95 Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 1:32pm
Crap....my eyes saw 7000 and my brain read 7000 series.
My bad, and apologies to OP.
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 1:37pm
Try Hammel Equipment in Chatfield Mn. They have scrapped a lot of tractors over the years. Ask for Troy
Edited by Lonn - 15 Jul 2020 at 1:37pm
Wink
I am a Russian Bot
Alvin M View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 3:16pm
Check Countryside Tractor In PA 717-923-0421 Part # 70260420
Edited by Alvin M - 15 Jul 2020 at 3:16pm
Ron(AB) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ron(AB) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 6:02pm
Swing the batteries out and you will see two site glasses.   There is no dipstick on a red belly.
That's were the fill plug is located too.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassguide Quote  Post ReplyReply Direct Link To This Post Posted: 15 Jul 2020 at 9:12pm
I am talking about the differential oil dipstick located at the back of the tractor above the 3 point
Tim NH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tim NH Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 10:21am
Finally had a chance to get your info. Overall length of dip stick sitting in tube is 13 7/8". Low mark is 1.5" from the end, and full is 2".
  Tim
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alvin M Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 11:09am
Countryside Tractor Has A Used One In Stock I Talked To Eli There Are In PA 717-923 0421
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 12:07pm
Don't dicker over price.....price a new one from AGCO!! Better be sitting down if anything like 8000series.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bassguide Quote  Post ReplyReply Direct Link To This Post Posted: 16 Jul 2020 at 7:25pm
Thanks for the info
