AC 6080 Starting Issue |
REM
Joined: 25 Nov 2021 Location: USA Missouri Points: 22 |
Topic: AC 6080 Starting IssuePosted: 05 Sep 2022 at 5:17pm |
I have a intermittent problem, when starting. Sometimes I get click sound when turning the ignitions switch to start. If I switch it off and try again it will usually engage the starter the second or third try. Sometimes it engages on the first try. I checked the battery voltage and it is fine.
Posted: 05 Sep 2022 at 5:26pm |
Kick down on the clutch pedal really hard. That safety switch is the usual suspect.
DSeries4
Joined: 12 Sep 2009 Location: Ontario, Canada Points: 7639 |
Posted: 05 Sep 2022 at 5:35pm |
PTO safety switches. There are 2 of them. They are the usual suspects.
MACK
Posted: 05 Sep 2022 at 9:28pm |
Install a relay between big white wire and starter if it don't already have one. MACK
