a-c 200 pto output seal |
Post Reply |
papa_t
Bronze Level Joined: 22 Oct 2010 Location: georgia Points: 22 |
Posted: 05 Nov 2010 at 10:23am |
does the lift shaft housing have to come off to replace rear pto seal on a 200.If so is there any thing unusal to look for?
Hurst
Orange Level Joined: 11 Sep 2009 Location: Midway, Ky Points: 1213 |
Is this a 2spd PTO. If so, it should be the same as a 7000, in which yes it does have to come off, as all the shafts and gears come out the side of the lift housing that is facing inside the rear end. Not really that bad of a removal if you have a good cherry picker (or a loader is what I used, probably not the safest...). One thing to make sure is that the PTO shaft that is inside the rear end housing just slides into a coupler at the rear. I would take off the rear end cover plate and have someone hold that shaft back in the tractor as you pull the housing off. If it comes out, there is a chance you can damage the seal between the compartments. I believe a single speed PTO can be done just by unbolting the carrier housing.
Hurst |
1979 Allis Chalmers 7000
5800 Hours |
Post Reply | |
