AC 185 injection pump wanted; |
KJCHRIS
Topic: AC 185 injection pump wanted;Posted: 22 Nov 2025 at 7:59pm |
I may be in need of a usable injection pump for AC 185. Let me know if you have one.
I'm in West Central Iowa, prefer 1 in reasonable distance if possible.
Pump driveshaft has sheared. First on Roosa Master for me in 50 years. ALL 6 line bolts came out of pump head by wrench all the way. I figure that means the head seized. Pump is clean and shiny like it had recently been repaired. I'm dropping it off at pump shop Monday to find out extent of damage. . I Found a pump drive shaft, sadly the inj pump was sold last spring. It's a shed find 185 that hadn't been run in about 5 years shows 32xx hrs. Brought it home Friday. Widow said it just quit after starting on a very cold day. I Put battery in before loading and cranks nice but no smoke no try run. Found problem today. Decided it looks far too nice to junk so I'm going to see if it'll run and go from there. Tires were what I was after. 2 rear still have tits on them, seats nice, lights work, paints good after bird poo washed off, 3 pt raised while cranking. Everyone enjoy your Thanksgiving day. For the other old guys on here don't over do on the desserts. |
pirlbeck
Joined: 01 Dec 2009 Location: West Central IA Points: 234 |
Posted: 22 Nov 2025 at 8:47pm |
You need to pull the injectors and have them pop tested before you try to start it with a good/repaired injection pump.
DougG
Posted: 23 Nov 2025 at 9:28am |
There tough to find,,
Edited by DougG - 23 Nov 2025 at 4:17pm |
brouillettefarms
Joined: 30 Jan 2013 Location: Vincennes Points: 331 |
Posted: 23 Nov 2025 at 4:09pm |
I have one from a running tractor, I can ship 812-881-7654
KJCHRIS
Posted: 2 hours 16 minutes ago at 8:48pm |
My pump can be repaired according to local pump shop. So I'll not need to buy another. Now to Finish a paying project so I can put this tractor where it's warm. Then I'll get hood, radiator, nozzles off tractor.
Had a 59 mph wind gust about 6pm and went from 39 - 31 in 2 hours but not as much wind. Snow in forecast for the weekend.
