AC 175D Engine oil problem?
NC Bruce View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Topic: AC 175D Engine oil problem?
    Posted: 07 Feb 2012 at 10:03pm
My favorite AC 175 Diesel has black oil leaking out of the manifold.  Looks like some is running down from muffler joint too.  BEFORE I get to take off the manifold for a look, WHAT are some repair possibilites I'm looking at....best and worst ideas?
Tractor cranks, seems to run good, not smoking noticeably more?.., has about 3700 hrs?
I was hoping for 'valve gasket leak' but it looks like only coming thru manifold.
Wish it could be a head gasket, but that's not a symptom, is it?
Does it sound like a bad Piston?  if so...why?
Any advice / ideas greatly appreciated!
*Lately, I noticed it was taking a little oil to top it off (on dipstick).  I was cutting, raking, and baling just a few round bales ( I know it's Jan, & my Dad would have had a fit....ha!...but missed my fall cutting...besides, hay was short and too dry..if you can believe that!!!)
MACK View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 07 Feb 2012 at 10:25pm
Could be a bad injector or not being worked hard enough to burn oil or fuel that got in manifold.  Put it on a good load and see if it clears up.   MACK
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 08 Feb 2012 at 8:52pm
you are probably right mack,had the same problem with one of my 45-d,replaced the injectors,dont slobber any more...
Steve Bright View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve Bright Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 8:03am
My vote is also INJECTOR
Post Options Post Options   Thanks (0) Thanks(0)   Quote NC Bruce Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 3:24pm
thanx fellows!  I had planned to pull the manifold and run it to see what's happening?
What's procedure for checking the injectors?    ...to find the bad one,
or remove all 4 and have them each tested?
thanx for any advice.....again!
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 09 Feb 2012 at 7:32pm
best to remove the injectors and put them on the test stand and have them run...
