AC 160 hyd
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Topic: AC 160 hyd
    Posted: 2 hours 29 minutes ago at 11:14am
i put on a new pump and new allis chalmers power fluid 821 bleed the system and now it will only lift at half throttle with weight on 3 point hitch and moves slow. How can i fix this?
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 1 hour 27 minutes ago at 12:16pm
Did you clean out the filter right in front of the seat, or check the O ring on that plate? If that screen is plugged or the o ring leaks the hydraulics don't work, or work poorly
