AC 160 hyd
John WV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Topic: AC 160 hyd
    Posted: 21 Feb 2026 at 11:14am
i put on a new pump and new allis chalmers power fluid 821 bleed the system and now it will only lift at half throttle with weight on 3 point hitch and moves slow. How can i fix this?
Kcgrain View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2026 at 12:16pm
Did you clean out the filter right in front of the seat, or check the O ring on that plate? If that screen is plugged or the o ring leaks the hydraulics don't work, or work poorly
Post Options Post Options   Thanks (0) Thanks(0)   Quote John WV Quote  Post ReplyReply Direct Link To This Post Posted: 21 Feb 2026 at 2:27pm
thanks  never th0ught about the o ring screen is clean
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kcgrain Quote  Post ReplyReply Direct Link To This Post Posted: 23 Feb 2026 at 11:34am
Might want to check the hose and clamps on the suction side going to the screen, the hoses are old and hard and can also cause an air leak, stopping the pump from getting its prime
