? about rear mounted sickle bar ...
jb from md View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Topic: ? about rear mounted sickle bar ...
    Posted: 27 Aug 2010 at 10:15pm
on my wd45 i have a sickle bar mower i dont know the model but it has a bracket that pins where the drawbar pins. the mower then slides onto the bracket with a pin that drops in on each side and is lifted by only the right lift arm. i think its a 7 foot bar. anyway i bought it a while ago and mounted it and there is a long spring that faces forward and goes almost under the axle where does this attach i have no other brackets or hardware its almost like its there to help with lifting or to assist in floating. does someone have a pic or describe where the spring attaches ... thank you Jb
Post Options Post Options   Thanks (0) Thanks(0)   Quote Skyhighballoon(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 10:25pm
jb - it's an 80R from what you describe.  Check out prior post with pics from Don Bradley.  Mike
http://www.allischalmers.com/new/forum/forum_posts.asp?TID=10989&KW=mower&PID=83700&title=wd-w-mounted-sickle-mower#83700
1968 Gleaner EIII w 10' & 330
1969 180 gas
1965 D17 S-IV gas
1963 D17 S-III gas
1956 WD45 gas NF PS
1956 All-Crop 66 Big Bin
Post Options Post Options   Thanks (0) Thanks(0)   Quote jb from md Quote  Post ReplyReply Direct Link To This Post Posted: 27 Aug 2010 at 10:40pm
thats it and i see what im missing. i do have the two flat pieces that bolt to the end of the spring i do not have that bracket that mounts up there by the fender. im sure it was most likely left on the wd that the man had it on when it was sold. i got the mower after the tractor was sold. i did get 4 s-c latches and two extra knives. now the hunt for that bracket is on... anyone have one for sale or could some one with it make me a print so i can make a exact copy. also thanks for digging up that old post... Jb
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 6:25am
Here is a picture of my WD-45 and 80R mower with conditioner attachment. The closeup is of the dolly bracket but you can see how the two flats are attached. I'm not sure if this is factory correct but it works good.
j.w.freck View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote j.w.freck Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 10:21pm
from what you described,you need the 'c'shaped bracket that attatches to the rear axel to att.the spring to.if you need the 'c'bracket i do have one that you can have pay for the ride.903-930-1387
Rick of HopeIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick of HopeIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Aug 2010 at 11:03pm
On the D14 mounting I remember a cable or spring that had to be attached to lift the bar at an angle when you lifted the main unit up with the rock shaft arms.
This page was generated in 0.088 seconds.
