A.S.A.E. Drawbar
Blake_AllisMan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Blake_AllisMan Quote  Post ReplyReply Direct Link To This Post Topic: A.S.A.E. Drawbar
    Posted: 25 May 2011 at 1:50pm
Hey guys I was just wondering how common the A.S.A.E. drawbar was? I have one on my C and I was told they were kinda uncommon. Any information would be helpful. Thanks Blake
1941 C
1952 IB
1947 C
1955 WD45 SFW
1956 WD45 Diesel
1977 5020 4WD Serial Number 1
Dakota Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dakota Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 3:39pm
they werenessqacary if you used any standard pull eguipment. I've seen alota of them. many have been butchered or are hanging on a barn wall. I had two of the triangle ones and an extra swining bar that I couldn't even give away they went for scrap a while ago.
Edited by Dakota Dave - 25 May 2011 at 3:41pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 6:30pm
Blake, can you post some pictures of what you have. I found a triangle piece that looks like it should be mounted on the front of my CA so I can push wagons around. I don't know where it came form or what it really is. Maybe I should keep it for my B and find dimensions for the support brackets that bolt to the seat frame.
Charlie175 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Charlie175 Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:07pm
ASAE
Charlie
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:16pm
Thanks Charlie, that looks like what I have. Now all I need is the strap size and dimensions for my 38B that go where your turn buckles are.
Edited by CTuckerNWIL - 25 May 2011 at 7:17pm
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 25 May 2011 at 7:37pm
  ASAE DRAWBAR WAS MEASURED FROM END OF PTO SHAFT TO PIN HITCH FOR PTO USES SO ALL MAKES WAS STANDARD [ALL COLORS]  THAT IS WHAT ASAE STANDS FOR  WAS STARTED BEFORE LOTS OF YOU WERE BORN BEFORE1940
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:11pm
I dug mine out today and it is different. It is 9 inches long and 6 inches wide and the 3 mounting holes are not in an arch or straight line.
GA-IN-TEXAS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GA-IN-TEXAS Quote  Post ReplyReply Direct Link To This Post Posted: 26 May 2011 at 10:29pm
INTERNATIONAL MADE ONE SIMILIAR TO THE A-C MAY BE WHAT YOU HAVE?
This page was generated in 0.110 seconds.
