A Little On The Tight Side |
Steve in NJ
Joined: 12 Sep 2009 Location: Andover, NJ Points: 12071 |
Topic: A Little On The Tight SidePosted: 30 Jul 2015 at 9:21pm |
Movin' things around in the garage and trying to get things cleaned up, I decided to install the Kohler V-twin in the 716H just to get it off the bench. It has to be raised an inch or so in order for the driveshaft to align up, but this looks like its doable.
Dgrader
Joined: 17 Jan 2015 Location: Newton,IL Points: 1037 |
Posted: 31 Jul 2015 at 6:56am |
JoJo's gonna like that Steve.
Ya cain't fix stupid.
tadams(OH)
Joined: 17 Sep 2009 Location: Jeromesville, O Points: 11401 |
Posted: 31 Jul 2015 at 3:26pm |
Does it have wheelie bars
Tom
HudCo
Joined: 29 Jan 2013 Location: Plymouth Utah Points: 4077 |
Posted: 01 Aug 2015 at 8:53am |
dont forget a hole in the bottom for that drain hose
fasstman
Joined: 07 Aug 2014 Location: Whitehall,WI Points: 150 |
Posted: 01 Aug 2015 at 11:17am |
It will fit my friend has a 25 vtwin in a 7014 simplicity. He has a widened tiller. The tractor does not even know it is back there at all. He also re pullied the bevel box to speed it up. That baby really moves.
Dave in PA
Joined: 13 Sep 2009 Location: Mars/Wexford PA Points: 2631 |
Posted: 01 Aug 2015 at 4:28pm |
DOOO YA THINK????? Steve might never see her again! Fire it up, go for a cruise, SHE will be just fine, and enjoy the ride!! ps Steve, it looks GREAT, can't wait to see the finished pictures here! |
ACmowerguy
Joined: 20 Apr 2010 Location: Winfield, MO Points: 1210 |
Posted: 01 Aug 2015 at 5:26pm |
That's interesting. When I put the command in my Sovereign the crankshaft centerline was perfect without spacers.
HudCo
Posted: 01 Aug 2015 at 10:50pm |
25 hp is a big block crank is lower in 23 by about an 1 inch just whent out and mausured my 25 and a magnum 18 both was 6 1/8
Steve in NJ
Posted: 02 Aug 2015 at 2:45pm |
Mike,
Where are you measuring from? Bottom of the block to the crank centerline? Just curious. |
HudCo
Posted: 02 Aug 2015 at 10:55pm |
both engines sitting on the floor so bottom of block to centerline crank k301 ,k321 same also ill bet that 23 is shorter
Steve in NJ
Posted: 03 Aug 2015 at 6:26am |
This engine is a CH18.
HudCo
Posted: 03 Aug 2015 at 12:40pm |
looked up specs 18 to 25 is all 6.125 dont know why i thought 25 was differant but i sure could not shoe horn it in the 616 if i read correct 18 to 25 are all the same width and hight
Steve in NJ
Posted: 05 Aug 2015 at 6:02am |
Interesting info. Good to know. Thanks Mike!
