A few 190XT questions.
Allis dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Allis dave Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 1:30pm
wow that's crazy. They were lucky. Do you know what caused it to flood so fast?
ezlle71 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2018 at 1:56pm
Around here creeks can rise and fall in just a few hours. The water had receded the next day we pulled both tractors out. Crazy stuff here in the flint hills.
190XT, 185, D15 SII, 7040 is living again, 7010 retired for parts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 10:06am
Got another question, Can anybody tell me where a good place to tee into the hydraulics on the 190XT for a loader without using one of the remotes?
Really don't wanna tie up one of the remotes for the loader all the time as we plan on puling the field cultivator with it. thanks
CAL(KS) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 10:17am
a loader valve with power beyond tapped into the pressure line in front of the tractor valve stack.  power beyond then runs to tractor valves.  discussed on here many times, a search would probably yield several discussions.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 11:30am
Sorry about that. I should have searched
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 11:51am
What's the trick to searching on this forum? having a difficult time getting results
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAL(KS) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Apr 2018 at 12:03pm
you can do a google search also if this doesn't get you what you want
"adding loader valve on 190" site:www.allischalmers.com
search topic in " "
this brings up a bunch of topics
Edited by CAL(KS) - 04 Apr 2018 at 12:06pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Apr 2018 at 11:35am
Surplus center has 3 different GPM loader joysticks. 10, 12 and 25. Would the 12 gpm be sufficient for my 190xt? From what i looked up the hydraulic gpm of this tractor is 12 gpm. I searched the forum and have the procedure for connecting to the tractor figured out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2018 at 10:52am
Wanted to give alittle update. Thanks to several people here, i got the 12 gpm surplus center joystick all plumbed in and operational. Have been very happy with the results all summer. The XT got to field cultivate, round bale, swath hay, drill sudan grass even got hooked to the plow alittle bit. Got some side shields from Abilene Machine. And at the request of the hired man and my dad, the XT now wears a 200 muffler. I will admit the muffler makes the tractor alot more enjoyable to operate. For next year, a sun shade was requested by the hired man.
During prairie hay mowing, the radiator sprung a slight leak. So i am gonna pull it and have it professionally cleaned and repaired. And gonna replace the water pump while its out, have new hoses all ready for it. While on that subject, i have heard of people using a different fan on these tractors for more or better air flow? if anybody can confirm that? Because i would make that switch too while i'm at it. Thanks
ez
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2018 at 12:00pm
More airflow to accomplish what ??  If you aren't having overheating issues as it is, why change anything when it comes to the fan ??  There's a reason a model 200 has two fan belts.....the different fan pulls harder.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2018 at 1:32pm
She was running alittle warm this spring working ground. 210-220 degrees pulling the 22 ft krause field cultivator about 6 mph. Maybe having the core of the radiator rodded and cleaned will take care of it. It would cool right back down when i backed outta it. So maybe i was worried for nothing. How many blade fan should a XT have? It seems to really move air so that's why i was curious how much more air a 200 fan will move.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 09 Oct 2018 at 7:34pm
A good cleaning might take care of your problem. If your fan belt wasn't TIGHT, the belt may have been slipping at high idle.  With the single belt at full throttle the belt has to be in good condition and tight.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 10 Oct 2018 at 7:56am
Thanks Doc! Thumbs Up
Post Options Post Options   Thanks (0) Thanks(0)   Quote ezlle71 Quote  Post ReplyReply Direct Link To This Post Posted: 22 Apr 2019 at 11:53am
Had to put new rear tires on the XT last friday. Ouch.  Got Firestone Super All Traction 2's in 18.4x34. Should be good to go for a while now.
