912 Hydr Tiller Belt pattern
john 1 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john 1 Quote  Post ReplyReply Direct Link To This Post Topic: 912 Hydr Tiller Belt pattern
    Posted: 05 May 2011 at 3:39pm
Can anyone tell me or show me how the belt for a rear tiller on a 912 Hydro goes on?
427435 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 4:25pm
Ask the question here or do a search on it:  http://www.simpletractors.com/club2/forum.asp?FORUM_ID=7
Mark
B10 Allis, 917 Allis, 7116 Simplicity, 7790 Simplicity Diesel,
GTH-L Simplicity
Ignorance is curable-----stupidity is not.
Post Options Post Options   Thanks (0) Thanks(0)   Quote john 1 Quote  Post ReplyReply Direct Link To This Post Posted: 05 May 2011 at 9:52pm
Thank-You!!!!
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 10:26pm
I see someone gave you a link to a complete manual over there.  It's a lot like this forum-----lots of good folks that will help if they have the info needed.
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote john 1 Quote  Post ReplyReply Direct Link To This Post Posted: 06 May 2011 at 11:30pm
When I click on the site he gave me I;m not finding anything?
Chris/CT View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris/CT Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 7:34am
Does your machine have all the appropriate drive parts on rear lift assy? Assuming it does, along with appropriate pulley on BevGear Box shaft sticking out left side, belt runs up along left side to that pulley. Depending on what drive you have [ Hydro/Var] has a slight variation. Best to get a exploded view of those rear pulley's, etc, that mount to rear hitch bar, and sort it out. Can you post a picture of the tiller mounted to your machine from rear?
I see you have a Hyd. Unit. Simplicity/Agco has a "deflector" pulley that keeps that belt from rubbing on the Hyd Filter. Brenda@ SandyLake Implement has the kit, along with copy's of what you'll need. The belt will do some serious rubbing on that filter, I had almost worn a hole thru mine!
Edited by Chris/CT - 07 May 2011 at 7:38am
Post Options Post Options   Thanks (0) Thanks(0)   Quote 427435 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 10:24am
See if this link works:  http://bsintek.basco.com/BriggsDocumentDisplay/default.aspx?filename=heCyEN8bqM2rE3Cvh5kbp796Dq
Go to page 6.
As pointed out above, if you have a hydrostatic unit, there's another idler pulley that mounts on the side of the tractor frame between the drive pulley and the hydrostatic filter.  That moves the belt down just under the filter.  My son bought a tiller that didn't include this pulley, but I made him one by bending some metal and mounting a pulley I bought at Fleet Farm.
PM me if you want a photo of this extra pulley and mount.
Actually, the pulley may raise the belt over the filter-----don't remember for sure.
Edited by 427435 - 07 May 2011 at 11:24pm
Mark
GTH-L Simplicity
Post Options Post Options   Thanks (0) Thanks(0)   Quote john 1 Quote  Post ReplyReply Direct Link To This Post Posted: 07 May 2011 at 10:55pm
Thank You very much for the link and the manual. I really apprecitate it!!
