912 H Making into Hydro Lift |
Doug Acord
Topic: 912 H Making into Hydro LiftPosted: 10 May 2019 at 8:21am |
I Have a 912 H that is manual Lift now. I Have a 7117 simplicity roller with all the hydro lift parts. I know I need the spring and valve out of the 7117 pump. I also know I need everything that was attached to the hydro lift on the tractor. Is there any reason why this swap should not work?
Mikez
Posted: 10 May 2019 at 10:16pm |
Good question. I'm woundering same thing
Roger Nolin
Joined: 12 Sep 2009 Location: Monroe Iowa Points: 189 |
Posted: 21 May 2019 at 4:32pm |
It will work. Just put hydro lift on My 914 with electric lift. We had to change the rockshaft the lift handle on because the hyd cylinder is bigger than the electric cylinder. Soak your lift handle where it mounts on the shaft so it will slide off easy.Good luck. Hydraulic lift is so much easier for me than the toggle switch on the electric lift and a lot easier on the batter
