82S sickle mower
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Topic: 82S sickle mower
    Posted: 13 Feb 2024 at 9:37pm
Last year I asked what guards others were using on their Allis mowers. I want to replace all mine before I paint it before mowing season arrives. Someone suggested the NH double guard but did not give me a part number. I cut pasture land with it and also orchard grass. I useTiger teeth sections but may go back to serrated sections with better guards. My AC guards are just worn too much to cut spring orchard grass when it’s really thick. It will clog between the section and guard. Called Hershel 2 different times and got 2 different opinions. All suggestions are welcome.
Thanks
Rob
1963D17 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 13 Feb 2024 at 10:52pm
If you go singles or doubles remember, smooth section-serrated guard. Serrated section-smooth guard. Most any single guard will work. I used the IH MC2041Z. The difference in the double guards is the back side where the knife rides. One has a built in wear plate. The other uses the wear plates you currently have. The best thing I did to my mowers and bean head is to install Crary adjustable holdowns. Schoup sells them. They keep the knife down on the guards. They are also tall enough to allow you to use section bolts.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2024 at 8:50pm
Thanks for your response. I was looking at a guard at RK, G81-0807 that my brother uses on his AC sickle mower. It has the serrated plate on it. So your saying use a smooth section with it? My wear plates are in good shape and I have almost new hold downs.
Edited by AC720Man - 15 Feb 2024 at 8:52pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 15 Feb 2024 at 8:57pm
Maybe I should get new smooth guards and try my Tiger teeth sections. They do cut very well and are almost new. My guards are just really worn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote 1963D17 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Feb 2024 at 10:38am
Take a look at the adjustable holdowns. You wont believe what a difference they make.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2024 at 3:22pm
Anyone use a NH 218 double guard? That appears to fit.
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2024 at 4:41pm
I have a rear belt and PTO cover if you are interested ?
I can bring to Boonville.
Edited by Macon Rounds - 27 Feb 2024 at 4:45pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC720Man Quote  Post ReplyReply Direct Link To This Post Posted: 27 Feb 2024 at 7:24pm
Macon, I hope that's a spare as those are difficult to come by. Best mower AC made IMO. Took me 3 years to find one.
