80-R mower lube???
tractorboy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorboy Quote  Post ReplyReply Direct Link To This Post Topic: 80-R mower lube???
    Posted: 01 Apr 2012 at 4:35am
I'm fixing up an 80-r mower, found a plug on top of round body smells like there was gear oil in it. What type should I use, and is it supposed to be full? Thanks, keith so. va.
Jim Lindemood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim Lindemood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 7:20am
Somebody will probably answer before I get back to you. My manual is in the barn -- not certain that I remember, but think they originally called for 20wt.oil -- but will have to check that.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 8:17am
I use 80 gear lube in mine.
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 10:23am
The manual says: Drive Housing: Capacity 1 Qt. SAE 20 or 30.
Do not let oil get below or do not fill above the driveshaft.
I got my mower long before I got a copy of the manual and
it had gear oil in it.  Hasn't used any, so it's still in there.
